eating gas
Old Feb 18, 2012 | 03:51 PM
hereticbrown's Avatar
eating gas
Have a 91 firebird 305 it's tpi I believe but I'm geting about 4-5 MPG what are possible reasons I need to look into fix this?
Old Feb 18, 2012 | 08:07 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: eating gas
Try running your fuel lines and check for a leak somewhere. Do you have a strong gas smell?
Old Feb 18, 2012 | 10:22 PM
Re: eating gas
Ill see if I can find one no real strong gas smell could it be fuel filter or something that regulates the fuel if so what
Old Feb 18, 2012 | 11:29 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: eating gas
maybe you live in a bad neighborhood ?
http://gasbanditblocker.com/
Some Walmarts carry them.
Old Feb 19, 2012 | 06:32 AM
jtsk's Avatar
Re: eating gas
There are some rubber lines at the tank that can dry out and crack, thus leaking. The fuel pressure regulator could be a problem, but that's not too likely. Its possible that it could be leaking at any joint in the system once the system is pressurized, most likely under the car because a leak under the hood would likely result in a fire. 305sbc could be onto something too.
Old Mar 12, 2012 | 02:46 PM
Re: eating gas
So I replaced the map sensor. And temp sensor still bad gas mileage anything else I should look into
Old Mar 12, 2012 | 06:22 PM
ex-x-fire's Avatar
Re: eating gas
The engine needs to run at 190-200* to get the best mpg. Get a good t stat in the 195* (stock) range.
Hook up a fuel pressure tester gauge, the psi should be 35-42psi or so running, It should hold psi when engine is off. If it doesn't then the injectors might be leaking, a bad regulator, line leak, ect.
Check ign. timing & make sure it advances when you rev it.
Plugged up exhaust from a bad cat.
Loose ecm grounds.
Vacuum leaks.
A dead o2 sensor.
Any codes?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
