Advice, is this supposed to look this way?
Old Feb 18, 2012 | 09:09 PM
Dezined's Avatar
Car: 91 Camaro RS - B4C option
Engine: L98 5.7l V8
Transmission: 4 speed auto
I'm not sure if this is called the crossmember or what, but I was getting under the car to jack it up, and was gonna use the jackpoint noted in the suspension 101 post, when I got under the car and saw this quasimodo here. I don't remember from other cars I've been under them being so mis shapen. Is this how they look? And is that what it's called, a crossmember?
Old Feb 18, 2012 | 11:29 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Advice, is this supposed to look this way?
It's a K member, and it's not normal.
Old Feb 18, 2012 | 11:34 PM
Dezined's Avatar
Engine: L98 5.7l V8
A k member, excellent. Knowing the name will help with searches. Being as i dont yet know what a normal one looks like, do you have a guess as to why this one looks that way? Im mostly wondering if its from the PO running over something, or if the car is in sad shape structure wise and is causing it to warp.
Im guessing also, that this isnt easy to replace without disconnecting a lot of other components correct?
Thank you for the reply
Old Feb 18, 2012 | 11:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It would have to have been involved in a serious collision.
Old Feb 19, 2012 | 12:05 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
yes thats the k-member, and WOW it took a big hit those are stout pieces!
Old Feb 19, 2012 | 12:09 AM
Dezined's Avatar
Engine: L98 5.7l V8
That's what I'm gathering. I'm really stumped, as no other part of the car looks, acts, or feels like it's been hit. Aside from one of the POs inability to do things nicely with the interior, it's a very nice looking car.
I however have no clue what I would be walking into if I tried to replace the k member. I don't have a shop, nor even an indoor place to work on it, so involved projects just aren't feasible for me right now. Starting to wonder if I should just sell it. Have only owned the car for a few months.
Old Feb 19, 2012 | 12:12 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
its very involved to replace it, but its not very difficult (if that makes sense). It may have been from bottoming out REALLY hard or something...
Old Feb 19, 2012 | 12:13 AM
Dezined's Avatar
Engine: L98 5.7l V8
At bare minimum it will require pulling the engine right? And do I run any risks if I leave it as is?
Old Feb 19, 2012 | 12:16 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
no you don't have to pull the engine, but you will have to support it somehow. I can't say without actually seeing it, but it looks severely damaged
Old Feb 19, 2012 | 12:21 AM
Dezined's Avatar
Engine: L98 5.7l V8
Well, not having to pull the motor is good news, I can always rent a hoist. I didn't look much under there, but I'm guessing the "involved" part comes from the front suspension? Did I see the control arms connected to it? I'd have to pull tires/wheels, brakes, struts/springs, the arms....not to mention finding another. Not sure if I want to go with a tubular one, this is only a daily driver, and third gens are a rare find in my area.
Whatta headache.
Old Feb 19, 2012 | 12:25 AM
Dezined's Avatar
Engine: L98 5.7l V8
I just found this thread
https://www.thirdgen.org/forums/susp...mber-bent.html
Is that going to be the same for an 88? If so, doesn't seem to bad at all.
Old Feb 19, 2012 | 12:35 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
All years and models are the same.
Old Feb 19, 2012 | 06:43 AM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
looks like someone hooked a chain up to it there to pull it out when it was stuck and gave it a big jerk.
Old Feb 19, 2012 | 01:29 PM
basiccamaro's Avatar
That bent part almost looks like a sheetmetal skid pan or something????????? It doesn't look like the lower control arm mounts are moved or anything heavy duty is out of place.
If it is just a sheet metal guard or something, no big deal at all.
Old Feb 19, 2012 | 02:02 PM
Dezined's Avatar
Engine: L98 5.7l V8
No, itsa major piece. Think i may have to ask a shop how much they'll charge to fix it. I just dont have a good area to work on it
Old Feb 19, 2012 | 02:04 PM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
thats definitely the bottom of the k-member, the three holes are a dead giveaway.
Pac J
May 17, 2020 10:44 AM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
