PCV Valve
Old Feb 28, 2012 | 07:22 PM
Pensfan11's Avatar
PCV Valve
Hi, I have an 89 firebird base model with the 2.8l v6. It has a rough idle, stalls ocassionally, and cuts out on heavy acceleration. I also noticed that there quite a bit of oil in my air intake. Could this be because of a bad pcv valve, I have already replaced my egr valve and if so where is the pcv valve loacated?
Old Feb 29, 2012 | 12:58 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: PCV Valve
The rough idle and cuts out on heavy acceleration sounds like a misfire. It could be that a plug isn't firing when it is supposed to.
Start with doing the usual engine troubleshooting for misfires, starting with a careful visual inspection of all of your spark-plugs.
Old Feb 29, 2012 | 07:39 AM
Pensfan11's Avatar
Re: PCV Valve
Ok, thanks :P
tyeo098
Nov 30, 2015 06:27 PM
sleprock
Sep 24, 2015 04:33 PM
CatmanFS
Sep 19, 2015 09:00 AM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
