need help with a cam selection please!
Old Feb 29, 2012 | 04:16 PM
LTR450rider's Avatar
I have a 87 305 tpi trans am 5speed and i want to buy a cam ive read on hear but cant find what i want i want a cam with a ruff idle and that adds some good power and i would like rocker arms,push rods and valve springs to go with it all the help i could get would be greatly appreciated
Old Feb 29, 2012 | 08:54 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: need help with a cam selection please!
is it 87 or 88 that got roller cams?
Roller is better, but you need a pretty big roller cam to get that lopey idle. Or to be more specific, lumpy roller cams usually have massive lift numbers that are impractical in your case.
TPI doesnt work past around 4500 RPMs anyway, so a lumpy idle wont work that well in your car.
If you dont care about performance, get the smallest roller thumpr cam you can get. It will be a dog to drive, but it will sound nice at least.
Old Mar 1, 2012 | 01:41 PM
do you think the 2032 crane cam would be a good choice and i think 87 got the roller cam
Old Mar 1, 2012 | 08:50 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
That is what most people in your situation use. 1987 was the start of the roller camshafts.
Since you have TPI, I highly suggest spending a lot of time in the DIYPROM section of this forum and learning to do your own tuning.
IMO, there's not a lot of use to upgrade all that other stuff unless you're going to pull the heads and do some other supporting modifications.
If your timing chain has high miles, then I would replace that with a true-roller (not a double-roller) set when you swap the cam.
There is a good bit of information concerning the upgrading of stock heads in my signature links below.
Old Mar 1, 2012 | 10:22 PM
thank you for your info and ill look into heads any suggestions
Old Mar 2, 2012 | 01:15 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I prefer 416 castings on a 305.
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
