If you had $2500 in my spot..
Old Mar 2, 2012 | 11:28 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
What would you do? I ask this because I honestly am not sure what to do at this point. Things to consider:
- I have a fully built 355 in the car right now. Everything is fairly modified, and it's ALL brand new. I actually haven't even driven the car with it yet because I've been building on it so long over the past 2 years. It will be done when I get back next weekend most likely (I'm leaving for Mexico in about 5 hours).
- I have a fresh 40 over block in the garage just sitting.. I've got enough to make a stroker out of it now, but I'm not entirely sure it'd be worth the cost of doing that. My current block is a 010, whereas this is a 880 roller block (intentionally did this for roller provisions). Not sure if this is worth the investment; then again I could sell the 355 in a few months and cover the cost of the stroker completely. I got a great deal on the block fromm a friend, so it would all even out.
- I have a full suspension, so I've got this covered.
- Interior needs front seats redone, or just replaced. The rest of it is just fine.
- Paintjob is happening in about a month, so this is also taken care of.
What I'm thinking as potential possibilities...
- new heads from Chad Speire and sending my Airgap RPM for a port match on them. They're about $1600 and port matching is $100.
- sell the 350 block and buy a dart aftermarket block and build a 406 out of it instead.
- save my pennies and go to a bigblock.. I'm not sure about this though. My goals are 10's at the most in the quarter. I'd be happy with low 11's honestly, and starting "all over" isn't exactly on my priority list.. and I don't want to do an LS1 swap; I've had one already.
- could get a good rearend for the car.. not a MUST have right now, though.. not yet, anyways.
- finding another T56 and completing the swap. I HAD one and sold it. Running a TH350 at the moment with a 2500 stall converter. Could also use some of that cash to buy a better converter.
It's not often I come across this kind of cash flow at once because I'm finishing school at the moment. What would you do with that kind of money?
Old Mar 3, 2012 | 12:21 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: If you had $2500 in my spot..
I vote heads and the T56.
Old Mar 3, 2012 | 12:33 AM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
I'm REALLY thinking this myself, but I don't think 2500 will cover both of those. T56 used goes for 1200 bucks, and that's usually not including the flywheel ($300), the clutch ($600), crossmember ($150), and the few odds and ends for conversion since I still have a mechanical speedometer.
FWIW: I have Dart Iron Eagle's at the moment if that doesn't clarify justification on the heads. I COULD always spend the cash to get them ported also, granted they're iron heads.. not that it really makes a difference to me what they're made out of besides the weight savings.
Old Mar 4, 2012 | 01:34 AM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
I'm also open to other suggestions, but I honestly can't think of much else.
Old Mar 4, 2012 | 08:25 AM
Abubaca's Avatar
You could have a blown LSx or a 2.8 V6. First mod I'd do would be a straight drive!!!! Hands down.
Old Mar 4, 2012 | 11:35 AM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Yeah, that's on my list. I really need to just drive the car and run it also, but there's still plenty of work to be done. I'm trying to get it ready for Gateway. Our dragstrip has been closed for several years now and it's finally opening up again this month.
Old Mar 4, 2012 | 04:42 PM
watajob's Avatar
Car: 92 T/A 'vert
I've NEVER brought in an automotive project at or under budget. Just sell a kidney or something!
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
topteam54
Oct 6, 2015 12:21 AM
MartinD
Sep 22, 2015 02:27 PM
Liveaction
Sep 17, 2015 06:29 PM
buckshot63
Sep 10, 2015 09:15 AM
