Top Speed?
Old Mar 4, 2012 | 08:28 PM
Mr. McGuire's Avatar
Car: 91 Camaro Z28
Engine: 305 V8 (5.0L) TPI
Top Speed?
What is the top speed of a STOCK 1991 Camaro with a 305 TPI with an auto trans? I was messing with this VW and the Z28 seemed to peek a 110mph. Thats what my speedometer goes to (110mph). Also whats the best way to increase top speed? I was gonna buy servo and governor kit and shift kit from Summit. Is that the right way to go?
Old Mar 4, 2012 | 08:36 PM
Sean O'Hara's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI
Re: Top Speed?
I know the top speed of my GTA with the 350 is about 130 mph
Old Mar 4, 2012 | 08:38 PM
Car: 91 Camaro Z28
Re: Top Speed?
I guess 110mph is about right if thats a 350.
Old Mar 4, 2012 | 09:04 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Top Speed?
Reburn the ecm chip so there is no limit in the code....Mines at 252 limit, even though it would never even get close to that.
Old Mar 5, 2012 | 08:39 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Re: Top Speed?
Its governed by the ecm not the trans. The transmission wont even hold 4th gear in wide open throttle.
Old Mar 5, 2012 | 09:13 PM
me420's Avatar
Car: 87 iroc-z
Engine: LB9 305 tpi
Transmission: t5
Axle/Gears: 9bolt BW 3.45 (G92)
Re: Top Speed?
ive had my z to 130+, white knuckling, windows open, t-tops off, and headliner freshly ripping in the wind. was old anyway and had slight sag. earned a excuse to fix it.
gotta say that upholstery orange stuff hurts your eyes, especialy......rippin'
Old Mar 5, 2012 | 09:16 PM
ghost91's Avatar
Car: 1991 Camaro Z28
Re: Top Speed?
I have the same and fastest ive gotten it before i got scared was roughly 127. even though the speedometer goes to 110, i estimate it at 127. i wouldnt push it much more
Old Mar 5, 2012 | 09:18 PM
me420's Avatar
Car: 87 iroc-z
Engine: LB9 305 tpi
Transmission: t5
Re: Top Speed?
yeah once i seen 130 i didnt count anymore but didnt let up either lol
Old Mar 5, 2012 | 09:32 PM
lolvtec's Avatar
Car: 1991 camaro RS convertible
Engine: EFI 383 150shot nitrous.
Axle/Gears: 2:73...
Re: Top Speed?
i got rid of my gov with a jet hot chip
91 vert top down i let off cuz of traffic
weeeeeeeeeeeeeeeeeeeee
Old Mar 6, 2012 | 12:46 AM
Chainlynk's Avatar
Re: Top Speed?
I topped out going down interstate 95 at 130 mph 3300 rpm in overdrive in my 86 trans am 305 carbureted 9 bolt rear 2.77 ratio. Speedo goes up to 140. It handled like it was on rails with the 406 I'm building I'm hoping to see the speedo start wrapping around!
Old Mar 9, 2012 | 08:23 PM
DannyJohnson's Avatar
Car: 1984 Pontiac Firebird
Engine: Carbureted 2.8 V6
Re: Top Speed?
I think the governor stops it at 115.
Old Mar 9, 2012 | 09:02 PM
utilityguy2's Avatar
Re: Top Speed?
There is no governor. The ECM program has speed and rpm cutoff limiters but they are set at 255 mph and 9544 rpm in stock configuration.
Old Mar 10, 2012 | 05:27 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Re: Top Speed?
135 with a freshened up lb9. some young punk got tired of being behind my wifes truck when i was a few cars behind and when passing he swerved hard at her..... needless to say the bird caught his camry real fast and some tricks were used to "school" him on driving etiquette. ive got mods to the trans to stay in 4th gear at up to 70% throttle.....
now that i got that outta my system, i didnt know tpi cars had any limiter? i know the tbi cars were 109 or something?
Old Mar 10, 2012 | 05:43 PM
Re: Top Speed?
Ah, must have only been for TBIs?
Old Mar 10, 2012 | 11:28 PM
Moody13's Avatar
Car: 88 Firebird
Engine: 305 T.B.I
Re: Top Speed?
Ive gotten my 305 tbi to 120 and it still had more...it took a long time to get it there.
Old Mar 11, 2012 | 10:51 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Top Speed?
Whether or not there is a speed limiter depends upon the year of the car along with what tires it had from the factory. The TPI cars that were factory equipped with Z rated tires have the speed limiter set high (254/255 MPH).
TPI cars with non-Z rated tires along with others such as the TBI and the 3.1l MPFI cars were limited to around 112/115 MPH. Even this varies to some degree, but they were limited in speed.
The older f-body's that were carb'd didn't have speed limiters.
The limiting is done by setting the injector PW to 0, thereby shutting off the engine.
RBob.
Old Mar 14, 2012 | 04:47 AM
IROZINCO's Avatar
Re: Top Speed?
140mph in my 350TPI 89 GTA on a flat stretch of road (at 5000ft altitude!) And it had more to go, i just ran out of straight road at that point! But the 91 definitely had a speed limiter, though for a stock 305, thats probably pretty close. Its not a hi rpm engine. Maybe 120 max...
Old Jul 14, 2014 | 12:18 AM
TysonNorthcott9's Avatar
Car: 1988 trans am gta
Engine: 5.7L V8 (L98)
Transmission: 4 speed auto
Axle/Gears: 3.07
Re: Top Speed?
I have a 1988 trans am gta it tops out at 188km/h (117.6 mph) it's a 4 speed auto with o/d and the 350 tpi it's a Canadian car I'm buying a chip for it well that make a difference ??? Or is there something else I gotta do to be able to go faster ( I have the digital dash when I switch it mph the cars speedo said 160mph as a top speed and in km/h it said a petty full 188km/h and soon as I hit 188km/h it well stay there it's at higher rpms too is it something with the tranny or the ECM ???
Old Jul 14, 2014 | 12:50 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Top Speed?
Stop being an idiot. Top speed is what it will hit in a 1/4 mile drag strip. Otherwise you need to be at least close to posted speed limits. You're gonna get people killed.
Old Jul 14, 2014 | 12:54 AM
Axle/Gears: 3.07
Re: Top Speed?
Im going to racing on top speed strip ... Which a 3/4 mile strip
Old Jul 14, 2014 | 05:43 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: Top Speed?
I have seen 140 in my 86. but its got a 2:73 gear
Old Jul 14, 2014 | 06:06 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: Top Speed?
Back in the early '80's (a young buck) I took my 70 bird past the 160 mark, I cringe every time I think about it (Ole geezer) now. I could'a killed myself and others......
Old Jul 14, 2014 | 10:14 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Top Speed?
But you're still here! Depends on where you are and what the traffic is like. In parts of Europe used to cruise well over 100mph. And in Germany you often have to get out of the way of guys that can afford to go much faster. It's not the speed that kills it's the sudden stop.
Old Jul 14, 2014 | 11:41 AM
Car: 86 IROC
Engine: 5.0 TPI
Re: Top Speed?
I do my runs very early in the morning. when there is less traffic and cooler air.i have a calibrated speedo and GPS. to check by.best run so far 147.
Old Jul 14, 2014 | 12:47 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Top Speed?
The difference though is that their roads are made to sustain said speeds of 100+, ours aren't and aren't maintained to either. One pothole, bad joint, heck...even a patch of dirt on the blacktop, at 100+ is trouble.
Old Jul 14, 2014 | 01:08 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: Top Speed?
Not all roads here are crappy. The conditions need to be acceptable. Includes road, car driver etc. etc. Some roads around me aren't good for more than 25mph!
Old Jul 14, 2014 | 04:33 PM
Restrorob's Avatar
Car: 88 GTA
Re: Top Speed?
It was around 1am when I pulled this stupid stunt and it was here;
It's 2.8 miles long and the span is about in the middle, Got off the throttle at the top...... I had two passengers that didn't believe that ole bird would fly......
Old Jul 14, 2014 | 05:46 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Top Speed?
RBob has the most correct information.
In terms of TPI cars with the 245/50/16 Z-rated tires (Goodyear Gatorbacks), there was no computer top speed. Just a transmission top speed. Manual transmission top speed being simply as fast as the engine will push it. Automatics on the other hand had a few different options.
All the automatics up to 1987 would let you run flat out. In 1988, the automatic was strengthened somewhat. But they also changed it so that you can't hold WOT in 4th gear. It will downshift to 3rd at aprox 66% throttle. This means that your typical TPI 305 or 350 automatic with the good tires and a 3.23 or 3.27 axle ratio will top out at around 120 mph. It won't stop accelerating at that point. But it will continue on in 3rd gear up into the red line and then some. Most of us don't want to be doing 6000 RPM in 3rd gear with stock valvetrain. So basically 120 mph is about what you're stuck with.
I've gone into detail about the hows and whys around the top speed runs here (post #11):
https://www.thirdgen.org/forums/tran...3-4-shift.html
Old Jul 14, 2014 | 09:52 PM
Car: 1992 Camaro RS
Re: Top Speed?
There's a huge difference between going 100 mph on the autobahn (Which is designed and built much better than the Interstate Highway system) where people EXPECT and watch out for cars going that fast and doing it here in the states.
Old Jul 14, 2014 | 10:06 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Top Speed?
My 89 formula 350 pegged the mechanical stop on the speedo which is 5mph over 140mph and it was still going.
I've been 240mph in a ford GT I modified.
Old Jul 15, 2014 | 07:48 AM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
Re: Top Speed?
Damn T-Top. I've only been 214mph in a UGR Lambo and 234mph on a turbo busa. You have me beat by a long shot. I need to step up my game for next year's TX2K15 event.
Old Mar 17, 2017 | 01:16 AM
Carl Ragsdale's Avatar
Re: Top Speed?
I have a 1989 with stock 305 .140,000 original miles. My top speed averages 122
Old Mar 17, 2017 | 10:15 AM
Drew's Avatar
Re: Top Speed?
1992 Trans Am
May 10, 2023 07:19 PM
deracer
Apr 11, 2016 12:04 AM
gta90
Sep 15, 2015 04:00 PM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
InfinityShade
Aug 22, 2015 08:00 PM
