82 and 83 functional air induction hood question
Old Mar 7, 2012 | 07:28 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
The hood on my 83 Z28 has the functional air induction flaps, as it's an Lu5 car. Well, the Crossfire set up is long gone, and with it went the "functional" part of my air induction hood. The only time that the air flaps do open now is when I plug my code reader in. Does anyone know which prong(s) in the ALDL make the flaps open when it is plugged? I want to run a switch in order open and close the flaps and bring the functional aspect back into my hood.
Thanks,
Chris
Old Mar 8, 2012 | 02:01 AM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Re: 82 and 83 functional air induction hood question
I'm not sure exactly how the ALDL plays into the switch, but here is a wiring diagram that should help:
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
Old Apr 15, 2012 | 01:16 AM
FormerL69's Avatar
Car: 1982 Camaro Pace Car
Engine: LU5 Crossfire
Don't have my manual in front of me, but when you use the old paperclip trick to jumper two of the terminals to retrieve any stored codes from the ECM by flashing the Check Engine light, that triggers the flaps to open. Your code reader has to get the ECM codes, so it is basically doing the same thing as the paperclip trick.
I want to say it's the upper right two terminals of the ALDL connector that you jumper together, but don't quote me and don't try it, as you might fry something.
Old Sep 1, 2012 | 07:00 PM
ChrisC's Avatar
To bring this thread back from the dead, can anyone else chime in on what terminals are the correct ones to pin in order to keep the flaps open? Can anyone back him up on his thoughts?
Old Sep 1, 2012 | 07:16 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
So cant u just run your own power wire and ground wire to the flaps and wire a switch in that?
Old Sep 1, 2012 | 08:01 PM
ChrisC's Avatar
You're right, the flaps are controlled by a solenoid that I could very easily wire power/a switch to, duh. I guess I was over thinking/over complicating a 5 minute job, haha.
Old Dec 10, 2012 | 03:20 AM
khunter's Avatar
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
Kinda stealing your thread here but correct me if im wrong. You have a carb on your motor and you're still able to fit the functional hood right? I have an 82 that has an iroc hood and im wanting to put a functional hood on. What carb and manifold do you have on yours?
Old Dec 10, 2012 | 08:59 AM
Jeffs82TA's Avatar
You are over thinking this, the CFI used the ecm to trigger the flapper motor. Just buy a vacuum switch from a 83-84 carb'ed trans am to trigger the solenoid. Basically this switch mounted on the firewall and under full throttle as vacuum dropped to zero switch grounded solenoid.
Old Dec 10, 2012 | 12:28 PM
ChrisC's Avatar
Under that hood I've run an Edelbrock Performer manifold with a Holley 570 dual feed, a Holley 4160 600, and an Edelbrock 1406. The key to clearance with the functional unit in tact is the air cleaner that you run. It's been a while but I removed the rubber from the hood that met with the original CFI air cleaner housing. I don't remember if it was because I HAD clearance issues or because I THOUGHT I was going to have them.
Old Dec 10, 2012 | 08:11 PM
khunter's Avatar
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
I have a holley high rise manifold and 750 carb. So I guess it's really just a mount the hood on and see if it fits. Ide love to see some pics if you have any.
Old Dec 11, 2012 | 01:35 PM
ChrisC's Avatar
I unfortunately don't have any pictures that would help with clearance..I have to ask though, is the high rise and 750 for your 305?
Old Dec 11, 2012 | 08:11 PM
khunter's Avatar
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
Yeah they were on the car when I got it it's the street dominator and street avenger series or which goes with which I'm not sure. But to answer your question I do have a 305 that has been rebuilt but I don't think was bored out any.
Old Dec 11, 2012 | 08:37 PM
ChrisC's Avatar
You're going to want to re think that combo..that 750 is way too big for a 305. I'm running a street avenger 570cfm and even that is considered to be over carbed. Realistically a 305 won't even need close to that.
Old Dec 11, 2012 | 11:15 PM
khunter's Avatar
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
Ive actually heard from a few people it was to big, truth be told i may need to pull a few things off i was told it has double hump heads and apparently you're not supposed to have them on a 305 either so i need to find out if its been bored way out or if its has alot of over done crap on it
Old Dec 13, 2012 | 05:27 AM
khunter's Avatar
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
Ok I went threw all of my paperwork and it is a 570 cfm carb
Old Dec 13, 2012 | 09:27 AM
ChrisC's Avatar
Assuming it is a street avenger model, the list number for the 570 S.A. model should be stamped as 80570, correct?
Old Dec 13, 2012 | 04:55 PM
khunter's Avatar
Car: 82 Z/28
Engine: 5.0
Axle/Gears: 323
I'm not sure I found the recipt from jegs and it said 570cfm. I'm not sure where I got 750 I guess I read it backward or what but like I said it was on the car when I bought it. I have a request can you give me your part number off your hood support struts? I've heard that they are diffrent than the ones for a steel hood.
Old Dec 13, 2012 | 06:03 PM
ChrisC's Avatar
Yeah sure. My car is at the garage, I should be going to do some work on it this weekend so it'll be a couple of days but I can get the numbers.
Old Dec 13, 2012 | 06:08 PM
ChrisC's Avatar
I ran the part through Autozone and came up with the correct support lifts for our hood. PN: E95976 or D95976.
Vintageracer
Jan 10, 2020 05:33 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
bryan623
Aug 10, 2015 11:33 AM
