performance problem
Old Mar 9, 2012 | 08:53 AM
sonicwolf89's Avatar
performance problem
i have an 82 with a carbed 350 out of an 85 k1500 and a TH350 trans from a 82 silverado.. im running a weiand street warrior intake manifold with a edelbrock 600 cfm carb. my timing is set at 10 degrees. the car just doesnt seem to have the amount of power coming from light that it should.. granted my kickdown cable isnt working for when i romp on it to pass someone been fighting with it for a couple months. i dont know if the transmission is to weak for it or if its the rear end. or maybe if i lost my marbles? i have had a little bit of metal flakes in the oil the last couple oil changes. i have been going through checking for vacuum leaks.. turned up the fuel mixtures and it got a little better but it still acts like its not getting enough.. maybe a 750 cfm carb might work better? idk im kinda stumped on it.. maybe i need to replace the crank bearings.. anyone have any ideas on this?
Old Mar 9, 2012 | 10:41 AM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
Re: performance problem
i would fix the tv cable before you blow the trans.
Old Mar 9, 2012 | 10:26 PM
it keeps coming loose down in the pan.. any ideas on how to fix it?
Old Mar 10, 2012 | 04:11 AM
gmstrong's Avatar
Your TV down in the trans is probably getting hung up on something i had the same problem i replaced the spring for the TV and it was fine after that.
Old Mar 10, 2012 | 06:15 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Pull the trans pan and see why the end of cable is not staying attached to the hook on the TV valve
If cable is fitted and adjusted correctly
there is no way it can come loose unless it is installed wrong or very stretched
or get ready to buy a new trans
http://www.tvmadeez.com/article/index.php
Old Mar 10, 2012 | 09:08 PM
85Z28383's Avatar
On a TH350 it is not a TV cable and you will not blow the transmission from not having it hooked up.
Old Mar 10, 2012 | 09:49 PM
yea its a cable hooked to a rod which hooks to a lever.. its been a major pain in the *** for me.. ive had the pan off it prob about 20x since ive had the car
Old Mar 11, 2012 | 04:48 AM
gmstrong's Avatar
Sorry missed the TH350,Was thinking 700r4 when i heard kickdown cable.
Old Mar 11, 2012 | 09:51 AM
i wish i had a 700R4 instead of the TH350 though i did notice there is a hard vacuum elbow coming off the drivers side of the transmission close to the floor pan that isnt connected to anything... and i dont know what thats in aid of
Old Mar 11, 2012 | 11:08 AM
This would be a problem... except that it should be on the PASS side, not the driver's; and it should be toward the rear, about right above the right rear corner of the pan.
That would be the vacuum modulator line. It MUST be connected to engine vacuum. That's half of the transmission's "eyes" on the outside world, the governor being the other half. The governor tells it how fast the car is going, and the VM tells it how much load the engine is under. (A FAR superior system IMO to the stupid "TV cable" idea... no idea why GM, after decades of using the superior and basically infallibly accurate VM setup, took a step backwards into Xler world with the stupid cable thing, but w/e.... it is what it is....) There was usually a small steel line from the trans (with a short "elbow" of hose at the VM) up to the motor, where another short pigatil of hose connected it to the manifold right behind the carb.
Without that, the trans will always think the engine is at absolutely 100% WOT 100% of the time, and will basically NEVER shift, at least not until the motor gets up to about 6000 RPM.
Sounds like it's time to check over the whole installation for missing / messed-up parts, and fix all that before worrying about bearings or carbs or any of that.
Old Mar 11, 2012 | 02:14 PM
the modulator line is hooked up.. this transmission came out of a truck. there is an open line on the drivers side just about straight up from the shift linkage. i could never find a diagram that shows me what hooked up to it. the trans shifts alright.. its just i dont know what it goes to
Old Mar 11, 2012 | 03:22 PM
No other line goes to the trans; that must be the vent.
Old Mar 11, 2012 | 10:39 PM
okay.. i was going to plug it.. good thing i was to lazy to crawl under it today.
Infested
May 22, 2018 11:56 PM
InfinityShade
Feb 21, 2016 01:29 PM
Reddeath210
Oct 6, 2015 08:20 AM
theurge
Aug 21, 2015 12:46 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
