91 v8 wont turn over or engage fuel pump
Old Mar 9, 2012 | 04:44 PM
royfoster1991's Avatar
Car: 1991 camaro conv.
Engine: 305 tbi
i turn the key nothing happens. i checked ignition wire and its good.all electronics still turn on
Old Mar 9, 2012 | 05:01 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 91 v8 wont turn over or engage fuel pump
Into or out of the switch?
Old Mar 9, 2012 | 05:07 PM
Engine: 305 tbi
from firewall. put new ignition switch in still nothing
Old Mar 9, 2012 | 05:35 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Batt cables clean an tight?
Check your fuel pump ECM fuse under the hood?
Old Mar 9, 2012 | 06:23 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
VATS
Will shutdown the starter if the pellet in the key is not read correctly
https://www.thirdgen.org/vats_passkey_system
try your spare key
Old Mar 10, 2012 | 02:50 PM
Engine: 305 tbi
if i arc the starter it will turn but wont fire
Old Mar 10, 2012 | 05:27 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
VATS
Did you read the link I posted above ???
Takes out the injectors ( no fuel ) as well as the starter
Old Mar 10, 2012 | 05:42 PM
Engine: 305 tbi
thanks . will try it
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
