Rough Idle
Old Mar 13, 2012 | 04:52 PM
Shane4524's Avatar
Car: 1986 Camaro IROC Z28
Engine: 5.0L 305 TPI
Rough Idle
When I first start my car up from it sitting for more then 20 minutes or so it will not idle. I have to feather the gas or else it will die. Once it gets going it runs just fine. I have seen somewhere or someone told me that the fuel filter and/or fuel pump needs to be replaced. Is that true?
Old Mar 13, 2012 | 04:58 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Rough Idle
You might have leaky fuel injector/s.
I would put a fuel pressure gauge on the rail and watch it closely.
If fuel injectors are leaking then the pressure will drop quickly when you shut off the engine.
Old Mar 13, 2012 | 05:54 PM
Shane4524's Avatar
Re: Rough Idle
If I shut it off and try and start it back up it will fire up right away, even within 5 to 10 minutes. Would that rule out the leaky fuel injectors?
Old Mar 13, 2012 | 11:20 PM
Shane4524's Avatar
Re: Rough Idle
I won't be checking anything on it till Easter weekend because I am away to college.
Old Mar 14, 2012 | 02:15 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Rough Idle
No.
That's exactly how leaky injectors act.
Old Mar 14, 2012 | 01:24 PM
Shane4524's Avatar
Re: Rough Idle
Originally Posted by 305sbc
No.
Alright, I see. Well, say I test the pressure and it goes down like you say it will. What all am I looking to replace?
Old Mar 14, 2012 | 02:00 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Rough Idle
Next step is to pull the rail up with the injectors still in it and do the test again.
You should be able to see if fuel leaks from the injectors and from which ones.
Sometimes the injectors still need to be warm for them to leak during the test.
At that point you get a good idea about what is going on and what exactly is wrong and may need replaced. Then you go from there.
If injectors are bad, then most people replace them with the newer style Bosh-3 type.
Old Mar 14, 2012 | 07:48 PM
Shane4524's Avatar
Re: Rough Idle
Alright, so if the pressure check out fine I should go to the fuel filter next?
If I end up having a leaky injector won't I have to replace all 8?
Old Mar 14, 2012 | 09:20 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: Rough Idle
Fuel filter has no effect on hot starting problems.
It's up to you how many you replace.
You can pull them all and have them all checked on a flow-bench, or mail them off to be checked.
Most people replace injectors in sets that are flow matched.
The flow-bench would show any differences in flow or operation.
Old Mar 14, 2012 | 10:10 PM
Shane4524's Avatar
Re: Rough Idle
Oh, alright. I have just been told the filter could be dirty. I will check it all out then. Thanks, and if anyone else has any input please tell me.
Old Mar 17, 2012 | 04:30 PM
Trans Glam's Avatar
Car: 1989 Trans am
Axle/Gears: 3.27 posi
Re: Rough Idle
I would check the filter first. if thats not it, it could be the injectors. Or the fuel regulator is bad.
Old Mar 17, 2012 | 06:50 PM
11ellswray's Avatar
Car: 1986 Camaro Z28
Engine: 385" SBC
Transmission: built out 700r4
Axle/Gears: 4th gen, 373, LSD, GIRDLE
Re: Rough Idle
bosh-3 type, where do most people buy these? because im searching summit and so far no good, and will these work for a earlier 350 car?
Old Apr 22, 2012 | 09:39 PM
Shane4524's Avatar
Re: Rough Idle
Update:
I had the fuel filter replaced. I watched the auto shop do it and then they checked my fuel pressure. It ran at 35psi and when they removed a vacuum hose it went up to 45psi. They said this is normal. When I shut the car off they removed the pressure gauge before I could see if the pressure dropped right away signalling a leaky fuel injector, as sbc305 stated above.
Old Apr 24, 2012 | 07:56 AM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Re: Rough Idle
Have you checked your intake manifold gaskets for leaks?
Old Apr 24, 2012 | 05:44 PM
Shane4524's Avatar
Re: Rough Idle
I have not, how do I go by doing that?
Old Apr 24, 2012 | 07:03 PM
Car: 1989 Camaro
Re: Rough Idle
A lot of people use carb cleaner and spray it around the intake to cylinder heads, around injectors, vacuum lines, and the power brake booster. The idle will smooth out real quick once you hit a spot with a leak and then die down.
Old Apr 24, 2012 | 07:49 PM
southbay08's Avatar
Re: Rough Idle
If you haven't purchased injectors yet and you are planning on replacing yours, we can help you. We have an extremely large inventory of various size bosch lll's. All tgo members receive a 10% discount. If you decide to purchase a set you can go to our website and at checkout just type in promo code tg11.
If you have any questions feel free to call us. Make sure you mention that you are a tgo member.
www.southbayfuelinjectors.com
516-442-4707
516-492-6504
Old Apr 24, 2012 | 09:49 PM
Car: 1989 Camaro
Re: Rough Idle
516-442-4707
516-492-6504
That's pretty sweet
Old Apr 25, 2012 | 07:22 PM
Shane4524's Avatar
Re: Rough Idle
Alright, I will give that a shot. It'll be a little over a week. I have exams coming up so I don't have a lot of time for it. I will post an update on what happens though.
Old Apr 25, 2012 | 07:28 PM
Shane4524's Avatar
Re: Rough Idle
Am I looking to get the Bosch lll 42lb or Bosch lll 36lb injectors? I am assuming 36lb because my car runs at 35psi ad then 45psi when the vacuum line is off.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
