Cannot get engine to crank
Old Mar 21, 2012 | 05:15 PM
Mpperry001's Avatar
Car: 1983 Daytona 500 Edition Trans Am
Engine: Carb 305
Transmission: NWC T5
Hi. I have been trying for three days to get this engine to crank over. I have an 83 trans am with a rebuilt 305 engine just put in. I connected all the wiring to the engine in anticipation for start up. Crank the ignition and all i get is the temp gauge jumping from 0 to past 200. I have checked and replaced the fuses, checked all my connections, replaced the fusible links to the starter, and replaced the battery cables. The battery is brand new and charged. I need help. This car is driving me insane. PLEASE someone give me some advice.
Matt
Old Mar 21, 2012 | 05:22 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Cannot get engine to crank
have you tried jumping the solenoid with a screwdriver? does it sound like its trying to do anything?
Old Mar 21, 2012 | 06:15 PM
Mpperry001's Avatar
Engine: Carb 305
yes i jumped it and the starter kicked in. It seems like its a wiring issue, but i cannot find whats wrong or where to start looking.
Old Mar 21, 2012 | 06:32 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
can you get someone to try and crank it while you check for 12 volts at the S wire on the solenoid? if its an older type solenoid, of course make sure the wire isnt hooked up to the R post. post your findings. might be something else, but just check the basics first.
Old Mar 21, 2012 | 09:22 PM
Mpperry001's Avatar
Engine: Carb 305
S
Old Mar 21, 2012 | 09:32 PM
Mpperry001's Avatar
Engine: Carb 305
So i was rooting around under the dash and discovered some loose wires. Can anyone help me out by identifying and telling me what they are for. This car needs to start soon, or its gonna drive me crazy
Old Mar 22, 2012 | 01:01 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Follow power through the starter circuit until you find the fault
Start at Ign switch , check for 12V on yellow wire in START.
Check for 12V at safety switch.
Similar problem in this thread
https://www.thirdgen.org/forums/tpi/...ton-start.html
Old Mar 22, 2012 | 10:40 AM
Mpperry001's Avatar
Engine: Carb 305
Thanks for the info. I am going to follow those instructions today. I will post my results.
Old Mar 22, 2012 | 05:35 PM
Mpperry001's Avatar
Engine: Carb 305
Ok i followed all of the instructions and finally got the engine to turn over. I tested all the switches and they all were getting power. So i took a look at the neutral switch, and found that it was not engaging fully when the clutch was depressed. I adjusted the switch and boom. The engine turned right over. Thanks redneckjoe and vetteoz for your help. Now i just have to get the engine started.
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
