High pitched "whine" from engine compartment
Old Mar 27, 2012 | 03:47 PM
jonny386's Avatar
Wondering what this could be? Alternator? Power steering? I dont think its PS becasue it turns fine the whine doesnt fluctuate with steering input.
Its just a very high pitched whine as soon as I start the car until I turn it off. Loud enough to hear at idle.
1992 RS 305 TBI.
Old Mar 27, 2012 | 06:26 PM
ex-x-fire's Avatar
Re: High pitched "whine" from engine compartment
Remove the belt & spin the pulleys by hand to feel any roughness or looseness.
Old Mar 27, 2012 | 10:38 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Does the sound change with engine rpm or is it constant with no change in rpm? If its power steering, the noise will usually get louder when turning the wheel. If its alternator noise, it might change when you turn on the headlights or some other kind of load.
Old Mar 28, 2012 | 03:16 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Most likely a belt issue, check that they are all tensioned properly, and not glazed or otherwise worn. If not that, its most likely the bearings in one of the accessories.
Old Mar 28, 2012 | 11:54 AM
jonny386's Avatar
Could it be a vaccum leak? Buddy said it sounds more like air than a bearing. I have changed the stock air cleaner to an open element, but I plugged the one vaccum line to the thermac.
Old Aug 13, 2012 | 11:09 AM
kfsullivan's Avatar
Car: 1988 Trans Am w/ WS6
Transmission: 5-Speed
1992 RS 305 TBI.
Did you ever get this resolved, as I am hearing the same thing on my '88 TA. A neighbor who has his own service business thought it was a belt bearing or the alternator (he did not actually see the car - just an educated guess).
Would like to know what you found out.
Old Aug 13, 2012 | 11:30 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
If you are only hearing the noise at idle, Especially with an open air filter, it is very likely air being drawn past the throttle blade and though the IAC. I hear it on my car since I installed ram air and the high flow air lid. The open passage from the front of the car to the throttle body transmits the sound much more than when there was the plastic and crud in the way. I don't mind the sound myself.
Another possible issue that I've run into on two different vehicles at the shop this year is excessive crankcase vacuum. These cars were both making so much CC vacuum at idle that air was actually being drawn through the front crank seal. It sounded like a dry bearing but it was coming from inside the front cover. I thought the first one might be a main bearing seizing up. In both cases, an overhaul of the PCV system(new valve, new filter) solved the problem. The diagnosis for it was simply pulling the PCV valve out of the valve cover. The noise goes away immediately, then takes just a second to come back after the valve is reinserted.
Old Aug 13, 2012 | 11:48 AM
kfsullivan's Avatar
Thanks for the reply. In my case I hear the noise pretty much all the time, and it increases as the engine it revved. My air filter is stock, and this inside the housing.
I will check the PCV just to be sure.
Old Aug 13, 2012 | 01:21 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Be sure to try removing the accessory belt and running the motor to see if it might be an accessory drive noise. You don't say what year your car is. Is it a serpentine drive car?(single multi rib belt)
Old Aug 13, 2012 | 01:42 PM
kfsullivan's Avatar
1988 Trans Am with TPI, thus only a serpentine belt. I should probably remove the belt and check pulleys plus have alternator tested.
Old Aug 13, 2012 | 02:32 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Oh yes. I didn't read thoroughly enough. Removing the belt will isolate the noise to the accessory drive. Then you can use a stethiscope to further pinpoint. The aluminum accessory brackets transfer noise very effectively, making it difficult at times to differentiate between engine and accessory drive, or even between different accessories. But the belt off test helps eliminate a possible engine problem. Bench testing the alternator sounds like a good way to go too, once you you have it narrowed down.
I remember a Ford Explorer with the 4.0 SOHC engine. The dealer who had sold it my customer(without him first having it inspected by me or another professional), had replaced the accessory belt and the tensioner in an effort to quiet a grinding noise in the front of the engine. I removed the belt and verified that the noise was in fact an internal engine problem. The customer then paid me for the 16 hour job of replacing the timing chains and tensioners, front and rear, on a car he had just bought. All because he hadn't had the car checked out before signing the contract. Takes a few minutes to remove and replace the belt and it would have saved him $1,000s.
Old Aug 13, 2012 | 07:53 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It is a common noise of TBI set ups when the base gasket drys out and starts to leak. This is the gasket between the TBI unit and the intake manifold. Although, I've thought of it more of a whistle then a whine.
Note that it is common for this to occur. Replacing the base gasket is quick and easy, even on the wallet.
RBob.
Old Aug 13, 2012 | 08:00 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Yes I would change that gasket first.
Old Aug 14, 2012 | 11:11 AM
kfsullivan's Avatar
RBob.
Good to know. I will check that out. Thanks.
Old Aug 15, 2012 | 11:48 AM
kfsullivan's Avatar
RBob.
Just a quick question. Is this gasket readily available at your typical autoparts store, or is it less common and may need to be ordered?
Thanks.
Old Aug 15, 2012 | 05:32 PM
Edwardgp's Avatar
Engine: 454-350
Probably 50/50 on that, give them a call.
Old Aug 16, 2012 | 07:20 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
The Rochester Dual Jet TBI was used on so many engines, in trucks, SUVs, and sedans throughout the late 80s to mid 90s that the TB base gaskets are everywhere. I install 2 or 3 a year and they are in stock at NAPA and Car Quest for sure, probably every other store as well.
Old May 6, 2015 | 12:07 AM
SparksAj's Avatar
Car: 1992 Camaro
Engine: v6 3.1
Transmission: Automatic
What would be the actual name of this gasket? I may need one
Old May 6, 2015 | 07:08 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
These guys are still talking about TBI base gaskets. Not TPI or MPFI.
Not sure if such a gasket would help you guys.
Old May 6, 2015 | 08:07 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Compressor bearing?
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
