How is this engine combo, finally putting this together
Old Mar 27, 2012 | 07:05 PM
Hawks831's Avatar
Car: 91' Camaro RS
Engine: Carbed Vortec 350 Lt4 Hotcam
Transmission: 700r4 2,600 stall
Okay, so i've been researching on here for a while and this is what I came up to for a good budget build. What do you guys think?
-Got a nice 350 block one piece rear main seal, roller cam .040 over
-Lt4 Hotcam
-98' Vortec heads, screw in studs, valve guides cut for cam ect..
-383 rotating assembly, scat crank, forged pistons, ect off ebay
-650 cfm holley double pumper
-air gap intake 1,500 to 6,500 rpm
-2,600 stall summit locking torqe converter
Im hoping to make decent power im hoping at least 350?
Old Mar 29, 2012 | 06:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
As long as the valve guides are cut sufficiently to handle the valve lift, and the intake is for Vortec heads, it should make a lot more than 350 gross flywheel HP.
Are you using 1.6:1 rockers?
IMissMy86TA
Aug 31, 2015 08:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
