350 engine/400 flexplate?
Old Mar 31, 2012 | 11:22 PM
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
ok, tomorrow i will dropping in my engine, the flexplate i pulled out of the car was very chewed up.
so my question is can i use a 400 flexplate if i pull the counterweights off? the engine is neutral balanced
thanks for all your input
Old Mar 31, 2012 | 11:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Are you willing to risk having to pull the engine or transmission again to save $30?
You may be able to remove the weight, but there wouldn't be any guarantee that it would be properly balanced afterwards.
Factory 400 flexplates are 168 tooth. 3rd gens used 153 tooth. Unless your block wasn't drilled/tapped for the offset starter mount, you should use a 153 tooth flexplate.
Old Apr 1, 2012 | 12:00 AM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
Re: 350 engine/400 flexplate?
i have a new 153 tooth flywheel and had it on once before, the starter didnt line up. do i need a different starter for the 153 tooth?
Old Apr 1, 2012 | 12:32 AM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
ok the reason is i have an offset starter, thats why i need a 168 tooth flywheel. does the parts store have one thats not weighted? and what make/model would i give them?
EDIT- after thinking about it, the starter didnt work because it was a 400 block, now the 350 will take the 153 and a stock type starter
Old Apr 2, 2012 | 10:41 AM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
i used a 153 tooth and a straight starter. thank you five7
Stangski09
Nov 14, 2015 01:27 PM
Vojtush31
Oct 11, 2015 01:07 PM
roysatikas
Sep 7, 2015 08:08 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
