harmonic balancer question
Old Apr 3, 2012 | 11:31 AM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
I'm getting ready to put a 350 short block together I purchased. I'm using as many parts as possible from my old 305 to save costs. My question is, can I reuse my old harmonic balancer from the 305 on the new 350 or is it advisable to purchase a new one. A new one is only 50 bucks but if I don't need to buy it, thats 50 bucks I can use somewhere else.
Old Apr 3, 2012 | 11:41 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: harmonic balancer question
You can use the old one.
Old Apr 3, 2012 | 01:33 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
I used the 305 balancer with my 350 no problem.
Old Apr 3, 2012 | 03:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Make sure you use the correct timming cover and balancer combo.
there are differences.
Old Apr 4, 2012 | 06:30 PM
Car: 91 GTA
Axle/Gears: stock
Thanks, for the responses. TTOP, what differences should I be aware of?
Old Apr 4, 2012 | 06:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/tech...ment-85-a.html
Old Apr 5, 2012 | 08:57 AM
Car: 91 GTA
Axle/Gears: stock
Thanks for the info. I'll be sure to check to make sure I use the right one.
Old Apr 16, 2012 | 04:08 PM
Car: 91 GTA
Axle/Gears: stock
Will any aftermarket harmonic balancer work with a timing cover with the timing mark at the 2 o'clock position or do I need a specific one? If so, do you have a P/N for the one I would need?
Americanmouse
Sep 7, 2015 12:10 PM
gixxer92
Sep 1, 2015 04:32 PM
theshackle
Aug 22, 2015 06:52 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
