My solution to the vortec head lift limits.
Old Apr 3, 2012 | 09:45 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
I really wanted to push the limits of a stock cast iron head, but the number one downside to them is the .480" lift limit. These started life as a bone stock set of 906 vortecs that came off a GM warranty core with 150 miles on it. Rather than trimming the top of the factory guide for clearance I decided to completely eliminate them and install a set of CHE bronze valves guides. Expensive you say? Yes. but not when you can do the work yourself. These heads will also be getting screw in studs and guide plates, 2.02/1.60 valve, Spring pockets cut to accomadate a 1.500" OD spring, and some serious time getting ported/flowed.
Here are some pics...
More pics to come...
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
bamaboy0323
Sep 3, 2015 06:07 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
