350 motor build qustions
Old Apr 5, 2012 | 08:31 PM
blwest187's Avatar
il buying a 350, i want it to b a duel carb with a blower/supercharger on it, i want it to push around 700+hp, how do i need to build the motor to handle the blower/supercharger and get around 700+hp, i have found the blower/supercharger for the motor already i just am goin to get it last, any help would b nice.
also wat would be the best trans for a car like this a plowerglide, t400 or a t350,
aslo wats a good rear end for a car like this
Old Apr 5, 2012 | 08:43 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 350 motor build qustions
1st up
Hp costs ; how much $$$ you have to spend??
In any case to get that sort of Hp reliably
( as in the motor not blowing up 1st time you drive it because you used el cheapo parts because your budget wasn't as big as your wet dreams)
you would start with a much bigger engine
Like this
http://www.hotrod.com/techarticles/e...e/viewall.html
Old Apr 5, 2012 | 09:05 PM
blwest187's Avatar
Moneys not a big deal, and can I make that much hp with a 350, cause I already have a 350, if need to b I can get a diff motor get that much hp I just don't want a big block
Old Apr 5, 2012 | 09:21 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Yes
but it will cost more $$ than using a larger engine because the smaller engine has to work alot harder and needs more expensive HD parts for it to hang together at that Hp level
The old saying ; no substitute for CUBIC inches
Because you need to buy all new internals for the engine you would make your 350 into at least a 383 ( no cost difference)
That 454 I linked is a small block same as your 350
Old Apr 5, 2012 | 09:28 PM
blwest187's Avatar
Ok,and I was going to take it to a 383, and I might look into getting a 454, so kinda of internals would It need, and wat would b the best trans for it
Old Apr 5, 2012 | 09:32 PM
blwest187's Avatar
And dont 350 cost less to buy parts for
Old Apr 5, 2012 | 10:48 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Doesn't matter if they are for 350 or 383
Same bearings /cam /heads/rods /etc
A SBC crankshaft of a certain quality is a SBC crankshaft ,
a set of pistons is a set of pistons.
Yes you can get 700Hp from a 350 but that would be a race only engine that idles @1500 ,has to rev to 7500 and have no fuel economy ; not what you install in a street car
Old Apr 5, 2012 | 10:55 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Not a straight forward answer
Google 700Hp SBC and see what experts say
Exp
http://www.1320techtalk.com/viewtopic.php?t=753
http://speedtalk.com/forum/viewtopic.php?f=1&t=27800
Old Apr 5, 2012 | 10:56 PM
blwest187's Avatar
Ok will do, do u have any idea wat would b a good trans for it
Jake_92RS
Jan 28, 2020 10:37 PM
italiano67
Dec 11, 2016 09:21 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
