Need help won't start
Old Apr 7, 2012 | 10:26 PM
ked5911's Avatar
I posted this in the V6 section but thought I might get more help here. So we have been trying to get our 1984, Carb 2.8L running for a while. We were having some fuel problems so we replaced the fuel filters, adjusted the fuel pressure regulator to 4.5 lbs replaced the carb with a reman we had and it ran ok for a while but ran rough. Oh yeh newer 2.8l with no mechanical pump so we put in an inline electric pump. We then got a ticking from the passenger side heads. Took them off and checked them and could not find anything wrong with the heads but found a small maybe 1/16x1/8th metal fused to one of the pistons. Broke it off and decided to replace the heads with some off of an engine we are rebuilding the bottom end on. The heads have maybe 1000 miles since they were rebuilt. All back together and now cranks but won't start. Plugs and wires are not that old, Checked cap and rotor and both were very worn so replaced still no start. Checked spark and not strong so new coil and changed the ICM as well. Reset timing several times. Firing order 123456. Started briefly but oil leak out of dizzy so pulled and got new O ring. We have fuel because we have pulled the plugs and they are wet. Lastly we tried to start and crank but no start, but we did get a backfire through the carb so we stopped. Any ideas on what else we can do? If we can't get it running by Monday we will have to tow it to a Mechanic because we are stumped.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
