IS IT WORTH IT? 90 VETTE HEADS..
Old Apr 12, 2012 | 08:53 AM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
Have a stock L98 w/ a ported plenun & base w/ SLP runners.
SLP air foil. Original throttle body (planning on changing soon).
I have a set of 90 vette heads lying around.. Was thinkin of rebuilding / porting.. Just not sure if it would be beneficial to do so..
Also, what specs should I follow.. (if worth it of course)
Old Apr 12, 2012 | 09:35 AM
88FormulaF_Bomb's Avatar
Car: 1988 firebird formula 350
Axle/Gears: 2.77
Re: IS IT WORTH IT? 90 VETTE HEADS..
if those heads are good enough for john lingenfelters projects they're good enough yours id personally use them. not sure on specs though keep looking around for that
Old Apr 12, 2012 | 01:15 PM
88 Z-ROC's Avatar
Thx.. will do
Old Apr 12, 2012 | 01:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
They are very capable heads if ported right. Can get good performance out of them. As said, lingenfelter had or still has a CNC profile for them that puts them on par with AFR/Dart/Brodix 180cc heads and the like. Not quite as good as most decent aftermarket 195 cc heads as the lingenfelters come out around 185 I think, but they are supposively good heads from what the vette guys are saying. I personally havent used them nor know anyone close that is but I dont doubt their capability.
Plan on a camshaft swap while your down there, that will really make it worth your effort.
Old Apr 12, 2012 | 02:47 PM
Axle/Gears: 2.77
pair ur ported 113 heads with a lingenfelter 211 cam if ur keeping ur factory style intake manifold
Old Apr 12, 2012 | 05:42 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Vette alum heads have no exh riser to match up to the F-Body intake ( if EGR required for inspection )
Old Apr 12, 2012 | 07:18 PM
88 Z-ROC's Avatar
So they should mount right up.. other than egr.. i plan on canceling out the egr
Old Apr 12, 2012 | 07:47 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
Nope the heads use the old style blot pattern so u have to elongate the 2 center holes not a lot of work, but u said u have a aft mrk base so they might did it already u will need a egr block off plate too
Old Apr 12, 2012 | 07:57 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
or just drill into #8 cylinder header primary or #6 and run the tube to the intake like the vettes do it
scoggin dickey used to sell a kit for that mod
FormulasOnly
Jul 23, 2018 08:47 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
