Possible oil pressure problem
Old Apr 13, 2012 | 11:05 PM
hondorian7's Avatar
Car: 91 Chevy Camaro RS
Engine: 305 TBI
ok so when i first start my car in the morning i have good oil presure around 30 and as my rpms go up so does the presure. but once the car is warm the oil drops to about 15 or ten and when i am at lower rpm i have no oil presure and sometimes the car will stall at a stop. is my engine toast or could this be oil pump problems. any help would be great thanks!
Old Apr 14, 2012 | 12:08 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Possible oil pressure problem
there are several posibilitys for the low pressure reading
including:
-worn oil pump
-excess clearance in the engine such as worn cam
bearings
-false gauge reading
Do you get any lifter clatter at idle with the oil warm?
Old Apr 14, 2012 | 11:09 AM
hondorian7's Avatar
Engine: 305 TBI
I dont notice any clatter but after I drove it and noticed low presure I havent driven it again just in case so I'm not a hundred percent about the noise
Old Apr 14, 2012 | 04:12 PM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
The stalling is because the factory oil pressure sender includes a fuel pump cutoff switch. I think it triggers around 4 psi of oil pressure. I would install a mechanical oil pressure gauge to verify the readings you are getting. I've had a sender break and it read really low. If your gauge is working correctly, you may need a new oil pump or an engine rebuild. The pumps is relatively easy to replace and you can disassemble it to look for damage/wear. If it checks out you need to pull the engine for new bearings, at the least.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
