Engine bogging down...really lost here...
Old Apr 14, 2012 | 12:23 AM
ScorchedBird12's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: TPI 5.0 V8
Transmission: 5-speed manual
Axle/Gears: Stock
So I finally got my car started and took her for a short spin today....From the get go the car felt weird. When I get on the gas the car hesitates before revving like it's about to stall, but catches itself and starts to rev. When I get out of first, the car does the same thing, sputters, then starts to propel the car forward. When I put in fresh gas the engine started to run smoother. When I'm finally rolling, the highest gear I can go is third before the car starts to lose power and stops accelerating even with my foot down. Eventually, the car stalled and left me broken down in the middle of a u-turn where I unhappily backed up traffic until I pushed the car aside. I can only think of a few situations off the top of my head that could cause this, but I could use some additional advice:
1. Certain cylinders are not igniting, maybe changing spark plugs and rotor will fix this?
2. Need a new alternator: Yeah this sounds off, but I did jump the car to get it started and after the car stalled it wouldn't start again.
3. New Battery: AAA guy put on his jump pack...thing was drained in seconds.
All in all, there also could be nothing wrong with the engine despite needing some iso-heet and fresh gas (car sat with tank quarter empty so water condensation in tank) but I'm also factoring issues with the chassis here:
https://www.thirdgen.org/forums/susp...ply-right.html
I mean I can't find anything else that could cause a loss of power in the engine except missing cylinders. But even an engine with missing power can still accelerate past 3rd gear but again once I hit third gear and with my foot down it slows down and about to stall.
I'm really lost here....
Old Apr 14, 2012 | 08:18 AM
ex-x-fire's Avatar
Re: Engine bogging down...really lost here...
Check your fuel pressure.
Old Apr 14, 2012 | 03:18 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
fuel injectors need to be ohmed
http://www.youtube.com/watch?v=lKKhYJd1gzg
Old Apr 14, 2012 | 03:31 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
put some fresh gas in there and a new fuel filter also. might wanna check your grounds too?
Old Apr 14, 2012 | 03:59 PM
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
my 86 z28 was doing the same thing it wound up needing a new fuel pump, filter, and fuel injectors needed a good cleaning and rebuilt
Infested
May 22, 2018 11:56 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Logan Bryant
Aug 27, 2015 11:52 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
