sea foam
Old Apr 16, 2012 | 06:53 PM
tcrisp's Avatar
Car: 1989 camaro iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 323
sea foam
has anybody use seafoam on a tpi motor ?
Old Apr 16, 2012 | 07:29 PM
ex-x-fire's Avatar
Re: sea foam
Yes, but I didn't pour it into the gas tank or crank case, I used it w/ a fuel injector cleaner canister. So the engine was running off a 50/50 mix of SF & gas. It was a maintence cleaning.
Old Apr 17, 2012 | 11:24 PM
TallTim's Avatar
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Re: sea foam
Added a can to vac line from charcoal canister. Split a can b/w gas and oil. Did not have a problem I was trying to solve, but if you think it cleans out your (whatever) I doubt it. Later pulled apart the plenum and it was grimy / dirty as ever. Under rocker covers dirty as ever, supposedly adding to the oil cleans out the sludge. I vote against it.
Old Apr 18, 2012 | 12:14 AM
ATCFLYBOY02's Avatar
Car: 1988 Iroc-Z
Engine: 350 TPI; Stock internals
Transmission: 700r4; TCI-CPVB; BW Hi-Frition
Axle/Gears: 4th gen 7.5 w/ 3:42 gear
Re: sea foam
Seafoam should be left in the sea... it sucks big fat donkey ding-ding...
Old Apr 18, 2012 | 12:25 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: sea foam
There is a lot of threads regarding seafoam, I have used it in my gas tank and seemed to work great! So to each their own. Do some more reading. Type seafoam in search bar. You will see all the threads and what others have to say!
Old Apr 24, 2012 | 10:13 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: sea foam
I use it in my Harley every year for winter sorage and it works great, I just put a can of it in the tank of my TA last night. I have never used it in the intake system or the crank case. It's good stuff to clean the fuel system out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
777Shock777
Oct 29, 2015 04:30 PM
GTA88
Aug 24, 2001 09:01 PM
ImportsRsloths
Aftermarket Product Review
Jul 3, 2001 04:58 PM
