Vacuum Line
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
Vacuum Line
82 CFI Z28. i have a hard plastic vacuum line that in the pics as i was pulling the motor ran across the fire wall. it starts on the pass side and runs to the driver side. i cant for my life figure out where it goes and i believe it may be the reason for my idle problems. anyone have a clue?
Car: 1983 camaro z28, 1981 honda cb650
Engine: Lu5 305 crossfire v8
Axle/Gears: 2.93
Re: Vacuum Line
What idle problems are you having? And you don't have a picture up. But there are also lines along the firewall that go to the wiper pump that look really similar to the vac lines
Car: 82 Z28
Axle/Gears: 3.43
Axle/Gears: 2.93
Re: Vacuum Line
well it plugs right into that little cylinder next to your wiper pump. I unplugged it and it draws less than a pound of vacuum and didn't hurt my idle at all even when I romped on it a little
Car: 82 Z28
Axle/Gears: 3.43
Re: Vacuum Line
i looked all over the pump and couldn't find a spot for it. its at work right now cause thats where I've been working on it. ill have to look at it tomorrow. i appreciate it. and i figured out my idle problem. i readjusted my rockers cause i heard a slight tick and after i started it up there was no more up and down in the idle.
Car: 82 Z28
Axle/Gears: 3.43
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Re: Vacuum Line
I believe that hard vac line operates the vents in the heat/ac system.
Car: 82 Z28
Axle/Gears: 3.43
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: Vacuum Line
Wouldn't stop the heat from working but would stop you from being able to change from floor to dash to defrost. It is the vacuum feed that feeds all the vacuum operated doors that direct the air flow of the HVAC system.
Car: 82 Z28
Axle/Gears: 3.43
Re: Vacuum Line
Car: 85 Trans Am
Re: Vacuum Line
Well my car is an 85 and the CFI cars are quite a bit different. Mine goes up right near the wiper motor where there is a T fitting. One goes to the vacuum ball and cruise control and the other to the HVAC system. I see your vacuum canister is behind the brake booster. My vacuum ball is located in the front bumper.
Also make sure your map sensor is hooked up to vacuum. That looks to be located just to the right of the vacuum canister in your picture.
Car: 82 Z28
Axle/Gears: 3.43
Re: Vacuum Line
Car: 85 Trans Am
Re: Vacuum Line
If you can't find a place for it you are better off sticking a screw in it and plugging it than leaving it open.
Car: 85 Trans Am
Re: Vacuum Line
I took some pics for you and found the HVAC line actually goes over to the passenger side. But it gets its feed by the brake booster.
Right behind my coil it goes into the harness which ends up going through the firewall.
I hope it helps on your 82
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Vacuum Line
I don't know the exact original plumbing, but it should be something like:
Intake vaccum goes to a one-way valve (to keep vac in the canister), which then T's off to the vac canister and the hvac hard plastic line.
If the path back to the intake is left open, you will have a vac leak. If you leave the hard line unplugged, you will have no hvac operation but no other ill effects so long as whatever pipe that goes back to the intake is capped off.
Edit: LilSki posted just before I did - his first pic shows the one-way valve - vac fed from picture left, and T's off to the hvac and canister on the right. In his case though there is no canister (later model), instead a hose goes off to the 'orb of power' in the fender (same function as the canister).
Car: 82 Z28
Axle/Gears: 3.43
Re: Vacuum Line
thanks ill have to take a look. hopefully yours is somewhat the same but i don't have anything like that by the booster. ill have to figure it out. if i can't ill end up plugging it. i really appreciate it though. I'm almost wondering if it was disconnected from before i even bought the car cause i don't even remember disconnecting it and none of that worked in the car anyway. i always thought the doors were stuck in the ducts. ill have to look deeper
Re: Vacuum Line
A lil late to answer but for anyone who still has this question, that vac line goes to the EGR Purge control solonoid that has an IN and OUT that is bolted along with the ignition coil I believe this line goes to the out and the in goes to the rear intake connection of the plenum on the passenger side
to be safe look up the vac line routing for the exhaust gas recirculation system and yes this will cause idle problems...hope this helps.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Vacuum Line
