1992 FIREBIRD 3.1 Idles rough when warm :(
Old Apr 29, 2012 | 08:42 PM
Kerch5's Avatar
Car: 1991 camaro rs, and 1992 bird 3.1
Engine: 305 tbi
Axle/Gears: granny gears
Hello, im noticing my car is idleing rough when ive driving it for 30min or more ... when i first start it up and cruise for the first 15 or so min it runs good and on the open road... but when i put it in park or i pull up to a stoplight it idles rough... i can see the rpm gauge jumping and the car feels like it wants to die but never has yet... just feels like its getting worse... general things ... 1992 firebird 3.1 ... new plugs, wires, o-ring seal... 100,761 miles... and run 93 octane, and already ran fuel injector cleaner... not very mechanically inclined but willing to learn.. thanks in advance for any help
Old Apr 29, 2012 | 08:49 PM
Kerch5's Avatar
Engine: 305 tbi
Re: 1992 FIREBIRD 3.1 Idles rough when warm :(
also wondering if headers would be worth putting on.. the pacesetter 2.8 ones... thanks
Old Apr 29, 2012 | 09:05 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
It could be a few things, but i think i would check the idle air control valve first.
Is the SES light on?
Another thing to check would be the EGR.
Also, check for vaccum leaks.
Old Apr 30, 2012 | 07:34 AM
Kerch5's Avatar
Engine: 305 tbi
No engine light... alright ill check those things ... thanks
Old Apr 30, 2012 | 11:03 PM
Kerch5's Avatar
Engine: 305 tbi
i cleaned the acv.. and unplugged the battery...nothing... no engine light but however oce the engine warmed up thhe idleing rough continued, and when the rpms jump the power dims aswell, temp of the engine is 160-170. i aslo bought a new fuel filter and a temp sensor that goes to the block... putting them in the morning as well as cleaning the egr... it might also b backfiring a little, not sure.... any other ideas? i was told it could b a bad cat converter 2? could that cause this? thanks
Kerch5's Avatar
Engine: 305 tbi
icv*
Old May 1, 2012 | 10:51 AM
Black88Z's Avatar
I dont think it would be the cats, but i wouldnt rule it out.
At this point i would say go ahead and put those parts you got on and see what it does, and remember to check for vaccum leaks.
Let us know how it goes, good luck
Old May 1, 2012 | 07:34 PM
Kerch5's Avatar
Engine: 305 tbi
OK, so ive put in a new egr valve, fuel filter, o2 sensor (one in exhaust), new temp sensor... cleaned the idle control valve... unplugged the battery... checked for engine codes... vacume lines...all to no avail... it seems to b missing causing the bad idle? it only does this when ive drove it for 20min or more and only when im ideling or in park... car never gets over 160-170 degrees, all fluids look good and not loosing any, anyone have any other ideas? (reminder car has new plugs, wires, oring, air filter) thanks again guys
Old May 1, 2012 | 10:42 PM
Black88Z's Avatar
Have you checked TPS?
When its cold, where does it idle at in drive?
Whats it idle at when warm in drive?
Old May 2, 2012 | 09:01 AM
Kerch5's Avatar
Engine: 305 tbi
ok so i went out and started it... idles at 1300 when cold... after 15 min it'll go dow to 900-700 range (tach bounces.. ) but then you can here the computer telling it to give more gas and then it will straighten out for maybe 20 secs 1000rpm, then its back down to rough idleing and repeat, is this a symptom of bad fuel injector?
Vintageracer
Jan 10, 2020 05:33 PM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
