where are the oil galley plugs?
Old May 1, 2012 | 08:07 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
im about to take my engine into the machine shop and i need to know where all the oil galley plugs and cam galley plugs but this is my first engine tear down and i dont know where the plugs are at so i can remove them, iv already removed all the freeze plugs but i just need to know these, i found this plug near the china wall on the driver side back by the bell housing and i have some similer plugs in my freeze plug kit ( http://www.summitracing.com/parts/SLP-381-4011 )
help please!!!
Old May 1, 2012 | 09:10 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: where are the oil galley plugs?
Might be one up front by the timing chain cover between wwhere the cover goes and the front intake gasket surface. There should be 3 on each end just above the cam holes. The rear ones are screw in where the front ones should be pressed in.
You can see the front ones here on my block. Note the block is upside down on the stand.
You can see the other three in this shot.
Old May 1, 2012 | 09:32 PM
Engine: L31 350
okay that knocks out those but what about the plug on the china wall? i can see it in your back picture aswell, also are there any other plugs like that one?
Old May 1, 2012 | 09:42 PM
LilSki's Avatar
Car: 85 Trans Am
As for the screw in ones like the ones in the kit you should only need 4. The one on the block deck/head surface and the 3 in the back above the cam. All 4 should use the same plug size. The one on the very top by the rear intake gasket is for you oil pressure sending unit.
There should also be a plug right above the oil filter but that won't be included in the kit.
EDIT: I Re-read you post and yes the one on the block deck/head surface is an oil galley plug and should be removed. Just don't forget to put it back before you put the heads on.
Old May 1, 2012 | 09:51 PM
Engine: L31 350
but i need to remove that plug above the oil filter before my block gets hot tanked correct? also do i need to remove all the bolts that are in the block aswell? i know on the passenger side there are 2 bolts in the side of the block acting as plugs i presum. im sorry for all the questions this is my first build and im just needing a few things answered
Old May 1, 2012 | 10:05 PM
LilSki's Avatar
Car: 85 Trans Am
I would remove everything and just note where everything came from so everything goes back I'm the right place.
Old May 1, 2012 | 10:11 PM
Engine: L31 350
okay thank you!!
Old May 3, 2012 | 11:18 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
On high performance engine builds, we generally tap the three front oil gallery plugs and install pipe plugs instead of the soft plug style. This is especially important when the block is to be modified for a double roller timing chain.
Old May 3, 2012 | 11:32 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
i would go with brass freeze plugs. JMO. dont forget the oil diversion plug. heres a link with a few pics.
http://forums.chevyhiperformance.com...ion/index.html
Old May 3, 2012 | 02:36 PM
Engine: L31 350
where are these plugs? And iv already bought my steel plug kit.
Old May 3, 2012 | 02:57 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
In the vertical oil galley.
Old May 3, 2012 | 05:26 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
did you click on the link and look at the diagrams and pics? cheap steel freeze plugs are known for rotting out quickly. again, JMO. id through them away and use brass. see what a few others say/think. your getting good help, and suggestions though. its up to you to follow them, or not.
Old May 3, 2012 | 05:34 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Brass is better, but steel is fine.
Old May 3, 2012 | 07:26 PM
Engine: L31 350
Steel only rots if they aren't painted and have pure water ran in the block, mine are getting painted and using only green coolent so I'm safe
Old May 4, 2012 | 03:10 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
I like to use brass and install them after the block is painted cause it looks cool. Just be sure to use some Permatex B on the freeze plugs so the don't leak. It also lubricates so they go in nicely.
Old May 4, 2012 | 03:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
And turn them all so the lettering faces up.
Old May 4, 2012 | 03:33 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
WOW! LMAO! for a moderator too? LMFAO!!!!
Old Feb 5, 2023 | 07:00 AM
SlowAndSteady's Avatar
Car: 86 Camaro IROC
Transmission: stock autom.
Axle/Gears: stock
Old topic
but finaly here is a complete list for all people comming
Here by Google search
3 cupstyle plugs at front behind timing chain
3 pipe plugs at Rear above camshaft Cover
1 pipe plug on driverside deck near pressure sending unit
1 pipe plug above oil filter
1 cup style "hidden plug" under main cap to divert oilflow tru filter
1 pipe plug above chain cover
Following things are to mention:
Dont forget to Reinstall the hidden plug correctely. To deep will cut off your oilflow completely. Small Step in the drilled hole should Set the Dept rigth. You can also check via the 2 Passages from filter. The feed should lead above the plug. The sending Passage should be open behind it. You can check by sticking a long screwdriver trough the hole on side of the filterhousing.
Before and after Installation there should be the same dept reading.
good tip is to tap the 3 front ones to recieve a pipe plug.
but be carefull with the middle one. A few millimeters in the hole it meets with the feeding passage to de front camshaft bearing. Going to deep will endup with fine pressure reading on your Instruments but a quick death of your New build engine
If you are super concerned or building an Performance engine it is a good tip to drill a small hole in the left front pipe plug (not in case of cup style) for extra lubrication on the chain. I think grumpy has a good instruction on that. Just google it.
Sorry for my bad grammar and word choices.
FireDemonSiC
May 30, 2015 10:19 AM
sailtexas186548
Oct 6, 2012 10:27 PM
Stonewolf
Jan 13, 2012 11:54 AM
bigEZ91RS
Mar 2, 2008 05:54 PM
five7kid
Sep 29, 2006 04:13 PM
