can yall help me please
Old May 5, 2012 | 08:30 PM
Sojer's Avatar
Car: 1987 IROC-Z red t-top
Engine: Nothing much
Transmission: I wish t56
Axle/Gears: 9bolt 3.27 4sale
23° HSR on 113 cast alm heads, stock port heads, 1205 intake, 1205 gasket. It runs idle up high that cut off. The intake hits the bottom and don't touch th heads as if it was a 20° intake. So I use RTV silicone on the china walls so it can touch the heads. This is what I did. Rubber gaskets on wall and felpro 9617 intake gasket, RTV on wall with 9617, cork and 2 1205 gaskets, RTV and 1 1205 gaskets. Its a 1987 TPI LB9. What can it be all hoses vac lines ben checked I will post vid. This 3rd gen is costing more than I want I'm bout to sell it it
Old May 5, 2012 | 11:38 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
Re: can yall help me please
Check your intake part number against the holley recommended part number. You may find a discrepancy there...
Old May 6, 2012 | 08:59 AM
Sojer's Avatar
What u mean its says use 1205 on the instructions intake pn 7540
Old May 6, 2012 | 11:44 AM
Car: 1989 Camaro
What I mean is to check your intake to make sure you didn't get the vortec intake, or the older intake by mistake. The heads are different and you will have installation problems.
Old May 6, 2012 | 12:32 PM
Sojer's Avatar
I got the HSR from a member on here he said its not, he had them on some dart heads. But it lines up with the head ports from looking at top with the plenum off. This the bad part of getting used parts the engine is not O.E. it was rebuilt by PO so it might been redecked. Can that cause that prob. It would open the angle of the heads right. If so I will need a new block and I will just go with a 350. My car won't be done this year no 3rdgen fest for me unles I can get it running right. Could it be a bad maf I have a new IAC
pwdbychevy
Apr 16, 2023 07:27 AM
Fox118
Members Firebirds
111
Jan 26, 2016 07:17 PM
Fox118
Sep 1, 2015 04:07 PM
Drone358
Aug 27, 2015 11:15 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
