oil change at speed lube left me with no oil help
Car: 1987 Sports coupe/z28
Engine: 2.8/ swapping 5.3
Axle/Gears: Open 3.42
I took my 350 tbi to get an oil change at speed lube before work.
Watched them put in oil because I lost an firebird to them forgetting.
Drive home, turn the car off oil guage says 60. Cut it on drive 8 miles to work,
Car started smoking thought maybe they spilled oil on the engine.
Get to work, check the oil its empty. Get them to look at it, and it's leaking
By the oil filter, squirting out when the engine is on. He thinks its a missing sensor
Any ideas before the look at it in the morning?
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Re: oil change at speed lube left me with no oil help
The old oil filter gasket didn't come off when they changed the filter most likely!
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Agree on both above!!
Does sound like they screwed you Again, this time by not checking the filter gasket came off the block-- Yup, it does happen!! Always make sure it comes off-- have the OWNER come to your house to look at what his
" Technician " neglected to do!!!!
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Car: 1991 Z28 1LE
Thanks for the fast replies. But I can really go anywhere that won't overprice.
And walmart won't work on a car older than 95. But they are going to look at it tomorrow and I
Will be there under the engine lookin too, what else should we look for?
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Maybe do it yourself from now on? That way you know it's done right and besides, an oil change on these cars is about as easy as it gets.
Yea, I don't know what I'm doing..if it wasn't for this site I wouldn't know anything about cars
Fair enough. But like I said, these cars are super easy to do an oil change on. Doing your own oil change is a great way for a beginner to learn how to wrench on their car.
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Yea, agreed with everything already said. jiffy lube, express lube, whatever you call it, there all the same, and walmart isnt much better. Either take it somewhere reputable, have someone you know can do it do it for you, or learn to do it. Theres very few things simpler than an oil change lol.
They probably did leave the old gasket on tho, i had a friend ruin his fathers brand new van that way. Went <100ft pouring oil out all over the road, seized the engine before leaving the block. This was on a chrysler tho... XD
Good luck tho, i hope it didnt cause damage. Something to check tho, check you oil for coolant in it and you coolant for oil. Theres a good chance you blew a headgasket or warped your heads if the engine ran too hot or too long without adequete oil. If thats the case, dont drive it. If theres coolant in the oil, you may need a rebuild because the coolant ruins the bearings inside the engine, as well as other things, ontop of the possible warped heads/blown headgasket.
Everything on the engine is rebuilt with racing performance parts including gaskets made to withstand extra heat so hopefully no problems in the morning when they check it
Car: 1989 Camaro RS--
Engine: MPFI
Wow I would be so ticked, believe me they would be paying for any and all damaged caused by such a small easy job. I agree with the other guys, learn how to change your own oil. Sorry that happened to you. I have never taken my car to a oil stop shop. Hope they didn't mess anything else up. Best wishes
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
Car: 91 formula
Engine: 350 tuned port. bolt ons
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
cmon,... i was changing oil at the age of 10... it isnt hard... the internet will teach you many things
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
^ I agree... I was doing oil changes when I was 14... and brakes when I was 16...
Well its not double gasket issue. No clue what it can be
BTW, if anyone discovers that a shop has left the gasket in place, discovers that the filter hasn't been appropriately tightened, or discovers that an incorrect filter has been used; and he returns to the shop, his privilege to own an F-body should be revoked for perpetuity
.JamesC
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Well if your oil gauge is still reading I don't think its missing the sending unit. A possibility is either its loose or there's a block off plug right above the oil filter. I could see if the sending unit was loose but someone would've intentionally had to of loosen the block off...
So the owner of the speed lubes owns 3 thirdgens and knows of this site. It was two gaskets on the oil filter like everyone guessed. He apologized, gave money to wash the car, wanted to clean the oil spill at my job, and put a quart of Lucas in my oil like I was going to do.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
So he gave you some oil, soap and water? This is the second time you should get a new engine.
eightsixseven
Dec 16, 2024 01:50 PM
Navy8125
Aug 21, 2015 09:32 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
