Will not start when engine is hot, mini starter fix?
Old May 11, 2012 | 03:08 PM
PicklesRgood's Avatar
Car: 1985 iroc-z
Engine: 355ci 1987 modified
Transmission: TCI turbo-350
Axle/Gears: 3.73 Richmond Gears
Hi, long time reader first time poster. I heard that when a normal starter is used with headers and a wide body oil pan if the car is hard to start after running for a while and warmed up the engine is hard to turn over (like the battery is dead). I was wondering if anyone else has had similar problems and if a mini starter solved them. I have shorty headman headers and some kind of Jegs aftermarket wide oil pan (came with 350). The motor was rebuild to an 11.5:1 compression 355. I would like to know if anyone things a mini starter would fix the problems and any suggestions about one.
Old May 11, 2012 | 06:47 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Will not start when engine is hot, mini starter fix?
https://www.thirdgen.org/forums/v6/3...tart-when.html
https://www.thirdgen.org/forums/tech...ank-again.html
Old May 24, 2012 | 05:14 AM
respawnformula's Avatar
Car: 89 Firebird Formula-maui blue/gray
Engine: 305 TPI 5.0 - getting 383 TPI!
Axle/Gears: 2.73 POSI / need 3.73(ANYONE ??)
I am having the same problem with a tci mini starter installed. So no it dont solve the issue. Wire a remote solenoid and get a heat shield to protect the starter motor anyway
Old May 24, 2012 | 06:34 AM
ScorchedBird12's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: TPI 5.0 V8
Transmission: 5-speed manual
Axle/Gears: Stock
I heard in these cars the starter is in a location where it will absorb heat and will give it trouble starting...I think they called it "heat soak." I have the same problem too. Had another firebird owner back in college who had the same issue...guy simply wrapped his started in heat wrap lol. Don't ask me how but he had no problems after that.
Frozer!!!
Jan 19, 2024 04:55 PM
mhatfield 14
Oct 24, 2015 07:48 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
milk
Aug 10, 2015 06:26 PM
