Check Engine Light
Old May 14, 2012 | 07:57 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
Check Engine Light
I have a check engine light I pulled the code 23: poor electricalconnection, open or short in circuit; defective MAT sensor, defective ECM, I recently changed the MAT sensor and to note the car was worked on by dyno don he didn't do anything wrong just looking for a quick response
Old May 14, 2012 | 08:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Check Engine Light
start with the flow chart, and check the mat connection next to the distributor.
Old May 17, 2012 | 01:35 AM
DiabloWS6's Avatar
I drove the car and noticed that the check engine light comes on after the car reaches or passes normal operating coolant temp
Old Jun 1, 2012 | 02:11 PM
DiabloWS6's Avatar
I noticed that the wire that goes to the egr is broken at the porcelain material would that affect the mat sensor ...the sensor is good only thing I can think of is faulty ecm ground
Old Jun 4, 2012 | 11:50 AM
sledheed's Avatar
Car: 1989 Formula 350
Engine: 350cu, Tune Port Fuel Injection
Transmission: 700R4, corvette servo
Axle/Gears: 3.23 Borg Warner 9in
Did you get this get this figured out. I have had same problem since owned mine? Very curious how u solved this? I know mine is warmed up when ch engine comes on? Quickly goes off when driving? Seems like as soon as it is not under load comes back on. Runs drives decent. Can tell by exhaust note it loads up, rich condition when ch engine comes one
Old Jun 4, 2012 | 12:22 PM
DiabloWS6's Avatar
Still figuring it out just trying to use the chart on top...same thing happens on mine check engine turns on as soon as it warms up but doesn't go away
Old Jun 8, 2012 | 06:01 PM
DiabloWS6's Avatar
What if I swap ecm to another one sensor checked out good wiring looks good
Old Jun 9, 2012 | 10:40 PM
DiabloWS6's Avatar
Well I swapped the ecm and same problem maybe the mat sensor
Old Jun 9, 2012 | 10:46 PM
Engine: Lb9
Transmission: M20
have you looked into the ground side. If I remember correctly the tps and mat splice for a common ground.
Old Jun 11, 2012 | 02:26 AM
DiabloWS6's Avatar
Will look at some diagrams on alldata
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
