Why does my engine rumble on deceleration?
Car: '84 Camaro - 2010 Surf Blue
Engine: 305 - 4 bbl Holley
Transmission: WC T5
Axle/Gears: 3.08
When I let off the gas, my exhaust sounds like it's rumbling and popping. I have an internally stock 305, w/o any emission controls, headers, 2-1/2" Y-pipe, 3" cat back (w/o cat), Holley 670 Street Avenger, Edelbrock Performer EPS and MSD Street Fire non-cc HEI.
Any ideas out there?
Car: 1991 Z28
Engine: 355 TPI
Axle/Gears: 9 bolt disc / 3:27
Re: Why does my engine rumble on deceleration?
Your not running enough horse to warrant a three inch exhaust first of all. Secondly you may be running too rich...
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
lack of back pressure will cause this.
Transmission: WC T5
Axle/Gears: 3.08
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
In my opinion a free flowing exhaust + manual trans will do this. A lot of race cars do it. There's nothing wrong with your car or anything, but with a manual transmission the engine acts a little differently under sudden coasting or engine braking scenarios than automatic cars do. You'll notice it a lot on the T5 5.0 Mustangs too. Just one of those perks of having a good exhaust on a manual trans car.
(Mine does it too).
(Mine does it too).
Engine: Lb9
Transmission: M20
Ive had white brother's and supertraps for my motorcycles and atv's. The way to tune those is to install a bunch of discs and then start remove them until the popping sounds is gone or almost gone.
Transmission: WC T5
Axle/Gears: 3.08
(Mine does it too).
(Mine does it too).
Engine: 4++,350 & 305 CIs
This is incorrect.
Backpressure is a bad thing in a 4stroke. 2strokes like a dirtbikes need some.
3" single catback is fine on a 305. The car may have a some unburned fuel lighting off in the exhaust due to a inj dribiling, timing issue, valve hanging open or a exhaust leak. Even a few other things can cause it.
Just a fun lil story. Back in the day of carbed cars we would go down the road in my old beater 76 chevy truck, shut the key off while still in gear, pump the gas pedal a bunch, turn the key back on then it would blow the mufflers apart!!! fun stuff right there..
lifetime warranty mufflers rock!!
Car: 1990 Formula Firebird
Engine: 350 (5.7) TPI
Transmission: WC T5
Axle/Gears: 3.42 POSI
I love that sound. On my old 305 I had in the 'bird, it was stock exhaust hacked at the front of the car with a small glass pack and I'd rev it and do a lot of engine braking just to hear that rumble and pop going down the road.
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I am on board with TT-TOP350 on this. I have seen this on many carbureted engines with free flowing exhaust. The open exhaust doesn't cause it, it simply allows you to hear it. The cause of the "pop" is unburned fuel combusting in the exhaust. The cause of this is generally either ignition misfire, lean misfire during decel fuel cutoff, leaky decel fuel cut off in the carb allowing fuel to pass, an exhaust leak allowing oxygen into the exhaust close to the hot manifolds, or leaky exhaust valves. Leaky injector(s) or a valve train issue will also cause it on an EFI car.
My Beasty did this one time when I first put the new valve covers on. I knew right away that the valve covers were interfering with my rocker arms, causing the valves to stick. A change of the rocker arms and verifying that the valves were okay solved the problem. I love the rumble of my exhaust on decel. I hate when cars pop. It always makes me think of an old beater truck.
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
You have a rumbling American v8. Smile and be happy about it. Some people have to put up with 4 cylinder imports that sound like kitchen appliances.
84z96L31vortec
Aug 20, 2017 12:16 AM
accelerator, alot, camaro, deceleration, decelleration, dies, engine, exhaust, firebird, gas, motorcycle, pop, pops, rumble, rumbling
also when shifting down gears
