Loud Bang on WOT
Old May 17, 2012 | 09:59 PM
WickedCrazy's Avatar
Car: '91 Firebird '85 Firebird
Loud Bang on WOT
I am looking for some help on figuring out what is causing a banging noise when I go to WOT from a standstill or slow roll. It just started and it happens when I smash the accelerator from a dead stop (not necessarily WOT but anything more then 50%) or when I go to WOT at anything rolling under 35. Ive found that if i ease into the gas from a roll and then slowly go to WOT it wont bang. Also if i roll into the throttle and then go WOT before it shifts into 2nd it will bang as the tires chirp. It sounds to me like its just behind the pass seat although it could be centered in the middle. At first I thought lower control arms, but after looking at them and trying to "flex" the bushings they appear to be ok. I also checked the rest of the bushings in the rear of the car and couldn't find anything amiss.
Any help with this would be appreciated.
Old May 17, 2012 | 10:17 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: Loud Bang on WOT
What kind of a "bang" is it? Like a clunk of something hitting something else, or like an explosion type bang? Could it be a "bang" in the exhaust? Like maybe something to do with the catilytic conv?
My little theory based on what youve said so far is maybe a cyl isnt firing, or firing strong enough, so some unburnt gas is going thru the exhaust valve still unburned and igniting when it hits the hot exhaust, causing the "bang" or "popping" sound you hear. Ive actually seen this happen before. Not promising thats the problem, but it may not be a bad idea to check all plugs for good spark.
What have you checked so far?
Old May 17, 2012 | 10:20 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
I'm going to assume you don't mean it's coming from the motor but when you lay into it two things usually happen - the motor torques towards the passenger side and the transmission down shifts.
Start simple. Check the trans mount, motor mounts, torque arm.
Old May 17, 2012 | 10:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Transmission mount
Old May 17, 2012 | 10:49 PM
Yeah its more like something is hitting. Trans mount huh? That i did not check nor think of. i will have to check into that 2moro. Thank you for your quick responses.
Old May 17, 2012 | 10:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I too would guess mount. Hopefully yours isn't one of those godawful fluid-filled monsters.
JamesC
Old May 18, 2012 | 06:59 AM
Wait.... There is a fluid filled mount? That I have not heard of yet. I was really looking forward to a nice easy fix for once.
Old May 18, 2012 | 07:03 AM
JamesC's Avatar
Actually, there are several different mounts. Pics/info below:
https://www.thirdgen.org/forums/hist...91-camaro.html
JamesC
Old May 18, 2012 | 07:38 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
yeah sounds like a trans mount
Old May 18, 2012 | 11:54 AM
86Stevo's Avatar
I dont know of this applies to automatic transmissions but with the 5 speed when u accelerate look to see if jr shifter is moving up and when u let off the gas if it drops back down and makes the bang.... Little trick to try out
Old May 18, 2012 | 03:00 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Automatic stick isn't seated directly on the trans so it won't work the same.
Old May 19, 2012 | 05:21 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
I had kinda the same issue on a firebird i had, first time was the exhaust mounts were loose, next time it was the torque arm. Hope you find it soon
Pac J
May 17, 2020 10:44 AM
86White_T/A305
Mar 6, 2016 01:48 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Damon
Sep 26, 2015 04:29 PM
