IAC & TPS Questions
Old May 21, 2012 | 07:34 AM
Damon23's Avatar
Car: 1992 Z28
Transmission: 5 speed
IAC & TPS Questions
I read the procedure to adjust the IAC and the TPS but if I buy news ones do they need to be adjusted out of the box?
Old May 21, 2012 | 08:50 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: IAC & TPS Questions
When I replaced my TPS and IAC on my 91 Firebird the only thing I did was take it for a 20 minute drive around town between 35 and 45 MPH to have the ECM relearn the IAC settings. Been running great since.
Old May 21, 2012 | 10:55 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Yes, you still have to set both the minimum idle air RPM as well a the TPS voltage when you replace the TPS.
The IAC motor will "learn" A/C load and other conditions over time. It might take a while for the idle speed to be exactly correct under all conditions even after you do the adjustments.
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
