Heads for my build
Old Jun 3, 2012 | 08:34 PM
RyanJB's Avatar
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Heads for my build
I'm not sure which heads would flow better, a set of Vortecs or fuelies (2.02/1.60 I believe). Will just be a 355 10:1 compression probably, I'm still in the planning stage.
Old Jun 3, 2012 | 08:53 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Heads for my build
For the 79 trillionth time, virgin Vortecs put ported fuelies to shame. All you really need to know is that Vortecs need a good bit extra exhaust duration and lift.
Old Jun 5, 2012 | 11:23 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
As atilla said, Vortec's will kick the fuelie heads *** any day of the week. They are weal on the exhaust side, I went with a cam with 229 degrees of duration on the exhaust(vs 224 on the intake) on my 383. 1.6 rockers on both, next time around im going to try a 1.65 rocker on the exhaust side to see if I make any gains.
italiano67
Dec 11, 2016 09:21 AM
deracer
Apr 11, 2016 12:04 AM
beastin91rs
Oct 9, 2015 07:38 AM
bdads
Aug 24, 2015 06:01 PM
89-S-dime
Aug 12, 2015 11:57 AM
