timing/car vibrating/no power
all stock 1989 350 iroc-z with mild cam upgrade
just replaced maf sensor, tps sensor, and distributer
i found TDC and when trying to time the car, i set it at 8* btdc with est unplugged with aldl jumped, it vibrates and has loss of power when driving down the block.
what could be causing this?
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: timing/car vibrating/no power
Make sure the firing order is correct, 18436572, CW rotation. Factory timing should also be set at 6* BTDC. Is the car throwing any codes?
