What cam to choose
Old Jun 3, 2012 | 09:25 PM
8494z2's Avatar
Car: 1994z28
Engine: lt1
Transmission: m6
What cam to choose
Whats up everyone, I just recently bought a 350 from a 87 iroc.It's going in my 84z.I'm going to rebuild it and switch it over to a carb set up.I haven't decided if i'm going to do a 355 or a 383 yet.I'm looking for some advice cam wise.I'm thinking about running the cc305 on stock ported heads.What do you guys think?It's going to be an A4, and I wanna run right around 350hp/tq at the wheels.I'd like it to be a little bit faster then my 94z 6spd.Any help would be greatly appreciated.Thanks in advance.
Old Jun 3, 2012 | 09:39 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Re: What cam to choose
Not tryin to be rude to anyone (this time) but your best bet would be to call up comp cams or crane, some company that makes em and they will give you your best matchup for what you have and want.
Old Jun 3, 2012 | 10:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
In which case you are far away from cam choice decisions
Old Jun 3, 2012 | 11:14 PM
8494z2's Avatar
Car: 1994z28
Engine: lt1
Transmission: m6
Right now i'm kinda leaning towards doing a 355
Old Jun 4, 2012 | 04:55 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Why choose a compromised cam if you're going carb? What gear? What converter?
Old Jun 7, 2012 | 02:46 AM
8494z2's Avatar
Car: 1994z28
Engine: lt1
Transmission: m6
gearing is going to be 3.73 and for converter i'm thinking right around 2500-3000 stall.I think i've figured out what i'm doing for a cam.I'm going to talk to lloyd elliot and most likely have him make me a custom grind
Old Jun 7, 2012 | 02:55 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Get your gameplan with your motor figured out first. Lloyd will take care of you. Great guy all around, actually.
Old Jun 8, 2012 | 10:47 PM
8494z2's Avatar
Car: 1994z28
Engine: lt1
Transmission: m6
Thats the hard part.I know what goals i wanna get out of, which i could get with with either a 355 or a 383.Moneys not a problem i just cant decide.I wanna run low 11s high 10s
Old Jun 9, 2012 | 10:45 AM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
You can get that easily provided you've got a well setup car. Go with a 383 if you're starting from scratch.. it will make things easier. I've got a 355 personally, but that also freed up some money towards everything else (which is where my money went). I saved money because I bought the shortblock off a friend. In your case I think you should just stroke the motor out and give it a nice custom camshaft. Don't use a shelf cam... that's silly. Get someone to talk things over with you and grind a camshaft out for YOUR goals and build. I suggest Steve at Lunati or Shane can help you at Bullet. They've both been the most helpful. Comps stuff is OK (I had a xe274) but that's old technology now. Lloyd Elliot also has some great grinds for his applications, and he'll sit and talk with you about anything.
Old Jun 10, 2012 | 01:27 AM
8494z2's Avatar
Car: 1994z28
Engine: lt1
Transmission: m6
True, I think thats going to be my best bet.I've always wanted to do a 383 too.So it's lookin like ill just go that route.I'll contact the two guys that you recommended to figure out what kinda cam I should get.Thanks for the help
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
