Shifting Problems
Old Jun 8, 2012 | 11:05 AM
jhuebner's Avatar
Car: 1987 Trans Am
Transmission: STOCK
Shifting Problems
I have a 1987 trans am. Yesterday i was cleaning my engine and today when i go outside to leave i started to notice the problems. I have a automatic car. I put it in drive then overdrive to see. the car will not shift out of first gear and i dont know why. could i of bumped something while cleaning it that will cause this?
Old Jun 8, 2012 | 12:40 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: Shifting Problems
It wont shift out of first at all? Or it takes a while to do it? (like up to 15-20mph)
I would check the detent cable first. It seems a bit far-fetched, but you may have bumped it while cleaning it up and knocked it way out of adjustment. That could cause it not to shift right.
Thatd be my first check of things. If you arent sure how to adjust it, look it up in your haynes/chiltons manual (hopefully you have one, theyre cheap and excellent to have, mine has paid for itself 100x over! ) or on this site. It varies depending on your engine.
someone972
Aug 30, 2015 12:52 AM
Frismund Snoid
Aug 27, 2015 11:08 AM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
