oil pressure low
Car: 1988 Camaro Iroc Z
Engine: 5.7 350
Transmission: 5 speed
Axle/Gears: not sure but got posi
oil pressure low
Ok new prob. Got my vibration fixed. It was that the tranny was not bolted all the way to the block. But now they changed the oil sending unit cuz it was leaking oil. The problem is I used to run 15 psi pressure during idle. Now I'm running 3-4 when it heats up. When you get on the gas it goes up to round 30. When you really get on it it will drop down to 0 after you let off the gas. Any ideas.
Re: oil pressure low
Wrong OPSU
They put in a 6-cyl one
The ACTUAL OP didn't change just because they swapped out the OPSU. Blee dat.
I was just in your general vicinity all weekend... Overland Park...
Engine: 5.7 350
Ok cool. So not going to hurt to drive it. Or did you put wrong one in lol I got work done in op by meineke
ambainb
Apr 25, 2016 09:21 PM
