Compatibility questions
Old Jun 23, 2012 | 06:50 AM
reconguy's Avatar
So when I get home from this deployment I have a 86 Z28 with the 5.0 TPI waiting for me to tear it down and build it up. But this is kind of my first rodeo with going this in depth so I wanted to give you guys the list of parts I want to put on it and see if it all works. I am actually forming this off a 350 HP build I seen online but the motors are different so I do not know.
Parts:
http://www.summitracing.com/parts/CCA-08-417-8/ Camshaft
http://www.summitracing.com/parts/CCA-17001-16/ Roller Rockers
http://www.summitracing.com/parts/TFS-30300002/ Heads
I have a set of headers waiting and I would also like to replace my timing chain and gears but I don't know what type to get with that cam or if that cam will even go in my block. Help? Thanks in advance guys.
Old Jun 23, 2012 | 07:27 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Compatibility questions
Everything except the pistons will interchange from a 305 to a 350 just so they both are early or later models. That being the newer models have a 1 piece rear main seal and the later ones have a two piece. If you are building up the 305 I would check the cam, it will fit but if the specs were off a 350 build sheet it might not be the right one IMO.
Old Jun 23, 2012 | 09:09 AM
reconguy's Avatar
The build was a 305 but a different type, I am not sure how much difference it makes but the one they used was an LG4 where as mine is an L69 I believe.
EDIT: I see where you got the 350 engine thing from that is actually meant as a 305 motor build that put out 350 horses. Sorry should have been more specific.
Old Jun 23, 2012 | 04:02 PM
Edwardgp's Avatar
Engine: 454-350
All right then good luck with your project just take your time and ask questions.c How many miles on the motor to be rebuilt.
Old Jun 24, 2012 | 02:23 AM
reconguy's Avatar
Odometer says around 90k but hell those things roll over at 100 thousand so I dont know, I plan on having the motor out and then taken to my buddies machine shop to get cleaned, honed, and inspected.
Old Jun 24, 2012 | 06:58 AM
Edwardgp's Avatar
Engine: 454-350
Yes the machine shop will take care of most of the things to make it a successful rebuild.
Old Jun 26, 2012 | 03:43 AM
reconguy's Avatar
So this cam that I want is a hydraulic roller and I keep seeing that it is not compatible with my year motor (1986 305 TPI) if this is true let me know and someone please explain to me exactly what I should do about it, scrap the cam and get a different type or is there someway for me to put it in with more modification?
Old Jun 26, 2012 | 03:56 AM
reconguy's Avatar
Correction it is a retro fit roller, dont know if it makes any difference but I really need to know for sure. Thanks guys.
Old Jun 26, 2012 | 07:05 AM
Edwardgp's Avatar
Engine: 454-350
That camshaft that you are looking at is for a boat. I think we can find something that would work better for you.
Old Jun 26, 2012 | 07:12 AM
reconguy's Avatar
Yeah lol I know it is marine but like I said, I was trying to follow a build, I am COMPLETELY open to suggestion on cams though, got any ideas of what might work out well?
Old Jun 26, 2012 | 07:59 AM
imeredith's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
The only thing that pops out at a glance is that you are going to have to pick up some new valve covers, as your current ones are center bolt and the new heads are perimeter bolts. Your '86 should already be a roller cam block, assuming it is the factory engine, so no need for any roller conversion kits.
Old Jun 27, 2012 | 12:52 AM
reconguy's Avatar
So I got in touch with GM and found out the roller cams weren't put in until 87, so now that leaves me with a couple of questions. One, is this a suitable replacement cam and two, I have heard of conflict between the TPI and perimeter bolt heads something about they dont fit right, you guys know anything about this?
New Cam: http://www.summitracing.com/parts/LUN-60102/
Old Jun 27, 2012 | 04:02 AM
poloaa008's Avatar
Old Jun 27, 2012 | 04:09 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I have a 350 pre-roller block with vortec center bolt heads and TPI Intake in my '88, not sure what you mean by "not fit right."
Old Jun 27, 2012 | 06:44 AM
reconguy's Avatar
Its something I heard, something about TPIs dont match up right with perimeter bolt heads.
Old Jun 27, 2012 | 08:06 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
If you've talking about the intake bolts, they won't match a head with the 4 angled center bolts along the perimeter because TPI '87 and I believe newer intakes have vertical bolts.
The TPI intake bolt holes can be slotted to fit, but you'll need angled washers, or adapters to keep the bolt straight. You may find someone who makes the adapters, which is what I would use. Last resort would be to get an aluminum rod of the bolt washer diameter, bore through for bolt diameter and cut at an 18° angle to make your own, 6" rod should be enough to make 4.
Old Jun 27, 2012 | 09:24 AM
reconguy's Avatar
So now I have to find out if the heads have those types of bolts.
Old Jun 27, 2012 | 09:29 AM
reconguy's Avatar
So looking at this pic I guess I do have those style heads.
EDIT~ So I cal TFS and they gave me a part number to the exact heads I needed http://www.summitracing.com/parts/TFS-30300006/ which just so happen to be centerbolt valve cover SHABAM
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
