91 Z28 idling to high?
Old Jun 24, 2012 | 10:48 PM
orangek's Avatar
So today after moving my Camaro in my driveway I let it sit for a bit since it hasn't really run in a little bit. While it was idling it was at 1500-1600. I thought it should be around 1000-1200 on idle. The rpm gauge might be off but I'm not sure. Any help to what may be the problem?
Old Jun 25, 2012 | 08:12 AM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Re: 91 Z28 idling to high?
Probably just warming up still. If its already warmed up, you said it sat for a little. Depending on what type of injection system you have in it, it's probably dirty. Ride it around and put some gas treatment meant to clean out FI systems. Or if you are carved carb gas treatment. After that drive it normally for about 20 minutes then start getting into it a little. Should clean it up. Also a tune up may be in order. Good luck!
jklein337
Sep 19, 2018 06:23 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Dialed_In
Aug 20, 2015 01:45 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
