Battery keeps dying?
Old Jun 28, 2012 | 04:50 PM
Jfinnkma91's Avatar
Car: 1984 Chevy Camaro
Axle/Gears: 7.5in 10 bolt with 3.08
I have a 84 camaro I rebuilt. Now If I leave the battery connected over night the voltage goes from 12.8 down to 4volts. I had a aftermarket tach hooked up but I disconnected the 12v constant power from it cause I thought that was causing the problem. But its still doing that. Any siguestions?
Old Jun 28, 2012 | 08:26 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Battery keeps dying?
Do you have an electric choke that is direct wired? Or a hood lamp?
Old Jun 28, 2012 | 08:35 PM
Jfinnkma91's Avatar
nope. choke is ignition on only. and theres no hood lamp installed
Old Jun 28, 2012 | 08:53 PM
jtsk's Avatar
The only other ideas I have are for a radio or power amp??
Old Jun 28, 2012 | 09:31 PM
KrazyFirst's Avatar
Car: 1988 Camaro
Engine: 305 TBI
Transmission: WC t5
Axle/Gears: Stock
Battery might not be holding a charge. Take it to autozone yo have them check it. Good luck.
Old Jun 29, 2012 | 10:33 AM
imeredith's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
You didn't specify whether the battery will hold a charge if it's disconnected over night? If it doesn't, then you have a bad battery. If it does, then you have a problem in one of your electrical circuits. Is the wiring harness stock or do you have aftermarket stuff directly wired either to the battery or the 'BAT' terminal of your fusebox?
Old Jun 29, 2012 | 09:43 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
do you have a hatch motor?My iroc would drain down if the rear hatch didnt click at the end of closing.worn out guilds can cause that.The other thing was the altnator had somthing wrong with it.It charged when running.but some times it would drain my battery.some resister that keeps curent from flowing backward in the alt would bug on me.
Old Jun 30, 2012 | 11:33 AM
Jfinnkma91's Avatar
I figured it out. I'm a big dummy. I wired my alternator wrong so it was drawing power with the car off. Oops.
Thanks guys
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
z28joe2
Sep 28, 2015 05:54 PM
Lmancha96
Sep 25, 2015 08:11 PM
lanceflame44
Sep 25, 2015 12:28 PM
