really nasty stripped hex screw
Old Jul 7, 2012 | 08:13 AM
davidjr74's Avatar
Car: 1985 Camaro Iroc
Engine: 350 tpi
on my intake plenum. I can't get this thing out for the life of me. Its stripped all around the edges and I tried drilling it out but to know avail. tried putting in some PB blaster didn't work. Try using a screw extractor and it just stipped it even more....
Only method I haven't tried was using vice grips and trying to turn it . Just need to find a new pair though mine are broken.
Any other suggestions? And I'm trying to do this so I can remove the rocker to check my EGR to see if its stuck.
Old Jul 7, 2012 | 08:42 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: really nasty stripped hex screw
You havent used vice grips? Thats about the first thing I'd try.
Old Jul 7, 2012 | 09:20 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Sometimes it helps to heat it up and then let it cool down a few times. It can also help draw in penetrating fluid as well. A sharp rap on the top with a hammer can also help break the initial bond/stiction. The amount of force you'll be able to apply isn't going to be as much now that it's damaged, so these other techniques come in handy in loosening it up so you can get it to turn.
You should be able to drill it if you can set an accurate divot with a center punch and use a bit made for metal along with lubricant. It takes patience, and accuracy is everything IMO (smaller bit at first and increasing gradually). Either way if you haven't done it before it might be better to take it to a pro that has experience especially if it goes into aluminum and/or the cylinder head.
Old Jul 7, 2012 | 09:39 AM
davidjr74's Avatar
Engine: 350 tpi
thanks fellas. will give it another shot.
Old Jul 7, 2012 | 10:43 AM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
If u have a welder just weld a nut to it and back it out.
Old Jul 7, 2012 | 02:26 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
You can also go to Sears or another tool store and get one of those sockets loaded up with metal fingers that are for removing rounded off bolts.
Old Jul 7, 2012 | 04:17 PM
stubby1962's Avatar
Car: 1989 IROC-Z
Have you tried a hammer and chisel to try and turn it out?
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
3rd gen money
Oct 11, 2019 09:57 PM
LT1Formula
Oct 8, 2015 08:34 PM
mcfastestZ28
Oct 5, 2015 07:12 AM
