Firebird problem..Help
Car: 1987 Firebird
Engine: 2.8l (173cid)
When I am driving my firebird at 55 and up it starts to act like it Is cutting in and out, Im not sure if it's a misfire of what and also sometime when you start to go up a hill and accelerate it doesn't do anything then you keep the pedal the In the same place it will just act like you just floored it and it is very annoying..I think that would be the spark plugs because the ones that are in the now are crap:/
We also put a new gas tank and fuel pump in and new ignition coil.
Any answers will help, thanks.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Firebird problem..Help
You're expecting advice and you can't even be bothered to identify the car?
Could your firebird be a 67 inline 6? A 73 SD455? An 89 TTA? An 02 WS6?
Get serious man.
Get serious man.
Engine: 4++,350 & 305 CIs
Also sounds like you have bad/cheap plug wires going bad.
Car: 1982 Firebird Base
Engine: 2.8L V6
Axle/Gears: Stock
You running the Air Conditioning? If you have a car that is already struggling, the AC compressor kicking in can make it feel like it's going to die on you... The compressor cycles on an off regularly, and whenever it cycles on, you can feel the car slow down.
I'm speaking from experience on this one, my carburetor needs a serious overhaul, causing the car to be under-powered to begin with... When I kick on the AC, It feels like I'm losing 1/2 my horsepower.
Car: 1987 Firebird
im not for sure what it is but we are going to replace the plugs with the stock ones and the wires and possable the distibuter cap and i dont run the a/c because it blows out hot air and i also dont think that the compressor comes on..i have been told it could my fuel injectors be stopped up..i drove it some today (cant drive it every day cause its been around 100 degrees here and i have no a/c)i was driving and gave it more throtle and it did not accelerate then it just jolted forward?!?!?!?!
Car: 1987 Firebird
honestly dude what would i be on here for if i didnt have a third gen car
why tell me to get real when you named three cars there were not third gen car?
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Give it a FULL tune up and then join us in the V6 board for less hassling... V8 guys can be rough.
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
