1984 Trans am need Help!
Old Jul 7, 2012 | 06:04 PM
scottmrit's Avatar
Hi i am having problems with my TA,and I recently purchased a Autoxray 6000 so that i could set Tps and the dwell. Well scanner says vehicle not responding. So i tried the paperclip method and no flashing check engine light. So i then checked ecm fuse and its good, then i checked the CEL bulb and its good. Well i am out of ideas and i am in need of help.
also CEL bulb doesnt light when key is turned on or car started.
The TA runs and drives fine it just gets 11 mpg and 14mpg on the highway. That is why i purchased scanner to i could adjust the CCC carb. Any pointers would be great.
thanks for the help thirdgen
Old Jul 8, 2012 | 02:14 PM
scottmrit's Avatar
Re: 1984 Trans am need Help!
checked inline fuse by battery that also goes to the back of the alternator. Its has 12v through the fuse. So does this mean the ECM is bad??
Jorlain
Aug 24, 2022 05:11 PM
colton_carlson
Mar 8, 2019 12:21 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
suzuki949
Aug 28, 2015 08:07 AM
Exxon Limited
Aug 9, 2015 08:13 PM
