Can you mess up your timing by adjusting only the advance on the distributor?
Old Jul 12, 2012 | 07:23 AM
Rich1's Avatar
did it and it ran better for 2 days but now pipe smells like gas
Old Jul 12, 2012 | 07:50 AM
Twin_Turbo's Avatar
Re: Can you mess up your timing by adjusting only the advance on the distributor?
What do you mean? Did you recurve the distributor or set the timing different? Year car? engine? carb?
Old Jul 12, 2012 | 08:05 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
How far did you rotate the distributor?
Old Jul 12, 2012 | 08:57 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Old Jul 12, 2012 | 02:35 PM
Rich1's Avatar
it was idling high so Turned it about half an inche to the left. Ran smooth and mad is alittle more quite and didnt want to take off on you.
but now im having lots of other issues.
its a 92 Rs 305 TBI
Old Jul 12, 2012 | 02:39 PM
Dakota W.'s Avatar
its a 92 Rs 305 TBI
Lol, you want a 5.0 to be smooth and quiet. If it's 20 years old it isn't going to be smooth, and a v8 muscle car certainly will NEVER be quiet. Turn your timing back to the right about half an inch, if not a full inch.
Old Jul 12, 2012 | 04:28 PM
Twin_Turbo's Avatar
it idled high and you turned it counter clockwise adding more advance? Turn it back and get a timing light
Old Jul 12, 2012 | 06:33 PM
Rich1's Avatar
I said that wrong i must have been thinging about other things. it was missing. not verry bad or loud. every so often you could here a change in decable level but I got that going ok.
Old Jul 12, 2012 | 06:39 PM
Rich1's Avatar
Help Help Help Car over heated!!!!!!
You replace on thing on a neglected car and all hell breaks loose.
Any way i was letting it warm up for 20 minutes.
standing over the motor making sure everything sounded ok and such....
Then i start hearing this shhhhhh sound looking at it i saw bubbles and water leaking slowly out.
I look at the temp gauge its maxed out...................
Long story shorter, Turn out the radiator fan doesnt kick on any more.
I called napa and asked if the water temp sencor can cause this and they said possibly??? like he was confused.
He also said theres a fan switch.
Which dignostics and tests should i do to fix my issue?
Before i start buying and replacing parts not needed to be.
Because im to damn broke
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
86IROC112
Aug 17, 2015 02:00 PM
midias
Aug 15, 2015 05:07 PM
