Overthinking head gaskets
Old Jul 13, 2012 | 12:59 PM
dfarr67's Avatar
Burned an valve on the RHS vortecs and decided to replace with AFR 912 Vortecs- recommended head gasket is FP 1003. Gasket taken off was 7733 for iron heads. Due to my location and not knowing my piston to deck dimension- I gambled and ordered a set of FP 1094 and GM 14096405...well guess what-it has been zero decked, .030 over bore. Live in northern Canada with extreme cold and am concerned with brinnelling. Gaskets I have been looking at are:
AFR says FP 1003
FP 1143 MLS
Cometic c5474-040
FP 1010
The Cometic is for the Vortec with the usual GM valve kickouts, the 1143 is round. The 1010 is copper wire. I've talked to a couple engine shops and they prefer the round style gasket, FP says the 1142 will be too small for the chamber- go 1143. I overlaid the GM on the afr chamber and it fits very well- so if going round it would have to be a larger diameter to seal correctly. Cometic is hard to get here.
Sooo what do you think?
Old Jul 15, 2012 | 10:07 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Overthinking head gaskets
Without bothering to look them up, choose whichever one has at least 0.037" thickness and the least crevice volume.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
