Starter clicks
Car: 86 camaro
Transmission: 700 auto
Axle/Gears: 308
Starter clicks
I have a 86 camaro it would'nt start and just had a solenoid clicking sound.I had a rebuilt starter put in, started it went to take the old starter back for my deposit,I had them check it and it was'nt bad. I got my deposit back,and wonder why my solenoid was clicking and it would'nt start before?Now when I let it sit for a week and try to start it just clicks like before but if I keep trying say 3 times it starts.I turn it off and it starts right up.I start it 3 or 4 times and it's fine.Only when I let it sit it has a new battery and good cables.Ignition switch maybe? thanks
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Starter clicks
If it is clicking I believe power is getting to the starter. Maybe clean the grounds and ground for the battery where it bolts to the chassis.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Starter clicks
Or your 'good' cables aren't. Not the ign switch. Is something draining the battery over time when it sits for a week?
Car: 86 camaro
Axle/Gears: 308
Re: Starter clicks
I have brand new positive cables,I replaced the ground wire and sanded the spot where it goes to the fender wall. But it does drain the battery if it sit to long,the negative cable has'nt been replaced would that cause the drain in the battery and not enough power to start the car and just enough to click the solenoid? I think I'll just replace the negative cable. thanks
Car: 85 IROC-Z Z-28, BLUE & SILVER
Engine: 5.7L & 5.0L
Axle/Gears: FACTORY
Re: Starter clicks
i had this problem last year and had to get a new starter and alt rebuilt... alternator wasnt holding up....
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: Starter clicks
New starter would probably be in order. You can have the alternator tested at a dependable auto parts store to see if it is flying south.
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Re: Starter clicks
I would always have my friend turn the key and give it little taps with a small hammer or a wrench, if it breaks free you need your starter rebuilt
Car: 86 camaro
Axle/Gears: 308
Re: Starter clicks
My first thread says I have put a new starter in already, and still have the same problem. What it was is the negative battery cable or I had the wire going to the fire wall too long,I shortened it up when I put in the new battery cable and starts every time no clicks!
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
Posted from Thirdgen.org App for Android
Linson
Oct 1, 2015 09:50 PM
