took the car out.. more problems
Old Aug 3, 2012 | 03:35 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
well, did another tune up, plugs, wires, cap, rotor, ect ect hoping to fix the previous problem. no luck, so im back on here. at idle engine runs decent, idles ok. when you throw it in gear and the rpms drop it acts like it wants to stall, and shakes bad. doesn't sound like a misfire. when you take off, between 1.5-3.5k rpms seems to be really sluggish, no ***** what so ever. it use to chirp the tires with ease, now u cant even make that happen, any ideas on whats going on. its a 86 iroc with a 305tpi.
Old Aug 3, 2012 | 02:48 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: took the car out.. more problems
Injectors perhaps? Also, verify fuel pressure is 35-40 at idle and 40-45 on throttle snap. Check MAF signal voltage. Should be about 4.5v key on engine off, about 1.6v at warm idle, about 4.5v at wide open throttle 4,500rpm under load. If MAF voltage won't go over 4v, you likely need to clean or replace the MAF sensor. Check your air inlet and filter for restrictions.
Old Aug 3, 2012 | 05:15 PM
jeff_blake's Avatar
Fuel pressure was excellent. I have a gutted air box, no restrictions theres. I'll check the maf voltage out though.
Old Aug 6, 2012 | 03:39 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Have you ever had the injectors out for service? If they are original, they are suspect in any power loss issue. Consider pulling them and sending them in to an injector service shop. They will clean and flow them, test the coils under load for any issues.
Old Aug 6, 2012 | 05:17 PM
jeff_blake's Avatar
solved yesterday. should have been the first thing i checked anyways but assumed it wasnt that easy.. bank 2 10a fuse. now its perfect. thanks all
Old Aug 7, 2012 | 02:00 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Cool! Gotta love simple answers to complex problems.
Ghettobird52
Jul 5, 2024 11:18 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
mustangman65_79
Aug 8, 2015 12:07 PM
