Way to check engine codes w/o engine dash light
Old Aug 4, 2012 | 11:24 AM
joef2002's Avatar
Hey everyone - 88 TPI GTA. In another post I have gotten some great help trying to diagnose a rough idle. Hoping their suggestions work. On another note...I was thinking of checking to see if any engine codes exist. I know where the port is and I have read about the paper clip thing. Problem is, my dash doest have the physical check engine light. Actually my entire stock dash is non existent (in modification phase).
Does anyone know if their is a way to check codes without relying on the blinking dash light? Local Auto stores don't have a obd I scanner. And I have a obd II scanner but the adapter port is obviously wrong. Are there inexpensive scanners I could buy that maybe have that "blinking light" built into them? Thanks gang.
Old Aug 4, 2012 | 01:38 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Way to check engine codes w/o engine dash light
Put a test light between pins A and D of the ALDL.
tnrednneck
Aug 13, 2015 08:57 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
