sound like the spark plugs are bad?
Old Aug 16, 2012 | 12:20 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
alright so heres the symptoms:
1. takes 2 cranks to start sometimes
2. loss of power
3. motor speed surge when i let off the throttle
4. when i get into it (wot or a little less) it stumbles and chokes up until i let off
5. high idle every once in a while when i restart it
sooo? what do you guys think? plugs?
Old Aug 16, 2012 | 03:27 PM
deadtrend1's Avatar
Re: sound like the spark plugs are bad?
I wouldn't assume plugs initially. I would look at fuel pressure and check for vacuum leaks.
Old Aug 16, 2012 | 03:32 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Do you run a K&N airfilter?? if so, try cleaning the maf.
Old Aug 16, 2012 | 08:59 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
hmm...well my very first thought was fuel filter so i might check that.
the hoses are ALL brand new
i do but i havent oiled it in a few washes.
Old Aug 16, 2012 | 11:50 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
could the maf being dirty do this?
Old Aug 17, 2012 | 09:25 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
I would check the plugs (or at least a few) to see how they look. My car needs new valve seals (dont they all lol) but it doesnt really hurt much, if it sits for a while (hr or more) itll take slightly longer to start up, but after that its fine. Even then if i shut it off and restart it starts instantly.
Id start with that and the easy things. Clean and oil your filters. DO NOT OVER-OIL THEM. thats how your iacv gets gunked up. Clean your maf. Clean your IAC valve. While your at it, clean your throttle body and wipe both sides of the blades down with a rag and cleaner (I like seafoam). Since its cheap and easy, change fuel filter. Check your TPS. Ohm fuel injectors. Check your CTS. Loan a vacc gauge and see how much vac your pulling. Even tho the hoses are all new you could still have a leak, and this will definetly rule vacc leaks out of the equation.
Afterwords, if the problem persists, check fuel pressure and maybe even timing if you think that could be the issue.
Old Aug 18, 2012 | 12:57 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
thanks dude very thorough will do when i get the time..thanks!
Old Aug 18, 2012 | 07:58 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Let us know what cleans it up for you.
Old Aug 19, 2012 | 09:22 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
will do
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
