89 Iroc wont stay running
Old Aug 16, 2012 | 07:17 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
Cousin has a 89 IROC with 5.7TPI. Had a code 34. MAF sensor wires were broken inside. ran rough. Replaced MAF sensor with a new one however now the car wont start without starting fluid and you have to stay on the throttle for a while to keep it running and then it will idle by itself most of the time. As soon as I try to put the MAF Sensor/Snorkel back on the engine dies. Also sounds like the car has High Vacuum. Dont have a vacuum guage with me to check it though. could it be sucking way too much air past the maf sensor and richening the mixture way too much thus causing the engine to die? Thanks!
Old Aug 22, 2012 | 04:30 AM
StringRust's Avatar
Re: 89 Iroc wont stay running
Any thoughts?
apo_bailon15
Mar 28, 2016 05:20 AM
ezobens
Aug 19, 2015 10:29 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Sherpajames
Aug 7, 2015 06:56 PM
